Wojciech Lepczyński
  • 7 Projects
  • 1 Followers
  • Aug 14,2026
6 Touchscreen Games for the ESP32 CrowPanel
Turn the 2.8-inch Elecrow CrowPanel into a pocket arcade with six original offline touchscreen games. Install it from a browser, then play solo or with a friend, with no Wi-Fi, SD card, or extra hardware required.
CrowPanel Pocket Arcade
CrowPanel Pocket Arcade is a compact DIY handheld gaming project built specifically for the Elecrow CrowPanel 2.8-inch ESP32 display.
Designed for its 320 × 240 resistive touchscreen, the project turns the CrowPanel into a small standalone arcade console with six original touchscreen games.
Once installed, everything runs directly on the ESP32. No Wi-Fi, Bluetooth, account, SD card, external game assets, or internet connection is required during gameplay.
Project website:
https://pocket-arcade.lepczynski.it/
Source code:
https://github.com/lepczynski-cloud/crowpanel-pocket-arcade
Video:
Six Games, One Pocket Arcade
The current version includes six games with different styles of gameplay, including reflex challenges, puzzles, an endless runner, a memory game, and local multiplayer.
Everything is controlled using the CrowPanel touchscreen.
Burst Hunt
A fast reaction game where bright targets appear in different places on the screen.
Tap the correct targets, avoid the red X, and build a combo before the timer runs out. Faster reactions earn more points, while incorrect taps break the combo.
Three difficulty levels are available:
  • Easy
  • Normal
  • Hard
Each mode changes the speed and pressure, making Burst Hunt suitable both for quick casual sessions and reaction-time challenges.
Shift Vault
A sliding-block puzzle played on a dynamically generated 6 × 6 board.
Swipe the pieces around the board and guide the golden key block toward the exit. Every puzzle is created using legal reversible moves, so the board remains solvable without relying on predefined level files.
The generated layouts make each round slightly different.
Star Pod Sprint
An endless arcade runner controlled with simple touchscreen taps.
Tap to make the pod jump over geometric obstacles, collect coins, and survive for as long as possible. The further you travel, the more demanding the game becomes.
Three speed modes allow players to choose between a more relaxed run and a faster challenge.
Line Four
A touchscreen interpretation of the classic four-in-a-row mechanic with original visuals and code.
Drop cyan and pink discs into one of seven columns and try to connect four pieces horizontally, vertically, or diagonally.
You can play:
  • against the local CPU,
  • or with another player using the same device.
No network connection or second controller is required.
Pair Quest
A memory-matching game built around 16 cards and eight procedural symbols.
Flip two cards at a time and try to find every matching pair. The symbols are drawn directly by the ESP32, so the game does not require downloaded image assets.
Pair Quest includes:
  • a solo mode focused on completion time,
  • a local two-player mode where players compete for the highest number of matched pairs.
Tile Slide
A classic numbered sliding-tile puzzle.
Move the tiles into the empty space and restore them to the correct numerical order. Players can choose between:
  • a compact 3 × 3 board,
  • a more challenging 4 × 4 board.
Each new game starts with a generated solvable arrangement.
Built for the CrowPanel
The firmware is designed specifically for the Elecrow CrowPanel 2.8-inch ESP32 with:
  • ESP32-WROOM-32-N4
  • 4 MB flash
  • 320 × 240 ILI9341-compatible TFT display
  • XPT2046-compatible resistive touchscreen
  • Landscape orientation
  • No PSRAM required
  • No SD card required
The interface uses large touch areas, bright status colors, a dark arcade-inspired theme, and cyan highlights to remain readable and comfortable on the small resistive display.
All six games are available from the same touchscreen launcher.
Improved Launcher and Interface
The launcher presents all six games as animated cards.
A moving highlight automatically travels between the game cards, making the interface feel active while still allowing the player to select any title directly.
In version 1.4.0, the animation was slowed down to make the menu calmer and easier to follow.
The interface also includes:
  • a 6 GAMES | OFFLINE footer,
  • a small touchable lepczynski.it label,
  • an offline About screen,
  • a QR code leading to my projects, GitHub, YouTube, blog, and LinkedIn.
The About screen uses the message:
Small screens. Big ideas.
Optimized Screen Updates
The ESP32 does not need to redraw the entire display continuously.
Frequently changing information, such as timers, scores, moves, and player turns, is updated only inside small screen regions. Static interface elements are drawn separately.
This targeted rendering approach reduces unnecessary refreshes and prevents visible flashing in games such as Line Four, Pair Quest, and Tile Slide.
Lightweight by Design
CrowPanel Pocket Arcade does not depend on large collections of game graphics or full-screen frame buffers.
Most interface elements are generated at runtime using TFT drawing primitives such as:
  • rectangles,
  • circles,
  • lines,
  • text,
  • grids,
  • procedural icons and symbols.
This keeps the firmware compact and allows it to run comfortably on the ESP32-WROOM-32 without additional memory or storage hardware.
Fully Offline Gameplay
The arcade is designed to work completely offline after installation.
Wi-Fi and Bluetooth are not initialized during normal gameplay. The games do not require:
  • network access,
  • external servers,
  • online accounts,
  • downloadable content,
  • background applications,
  • cloud services,
  • an SD card.
Just power on the CrowPanel, select a game, and start playing.
Install from a Web Browser
The firmware can be installed from the project website using desktop Chrome or Edge:
The installation process requires only a data-capable USB cable:
  1. Connect the CrowPanel to the computer.
  2. Open the project website.
  3. Select the installation option.
  4. Choose the correct serial port.
  5. Follow the browser instructions.
There is no need to configure Arduino IDE, PlatformIO, libraries, or an ESP32 toolchain just to try the project.
The source code remains available for anyone who wants to modify, rebuild, or extend the games.
Open Source and DIY
CrowPanel Pocket Arcade is an open-source project written in Arduino C++ and built using:
  • PlatformIO
  • TFT_eSPI
  • ESP Web Tools
  • procedural graphics created directly in firmware
The project is released under the MIT License.
It can be used as a ready-to-install arcade project, but it can also serve as a starting point for experimenting with:
  • ESP32 touchscreen interfaces,
  • small handheld devices,
  • procedural graphics,
  • local multiplayer,
  • puzzle generation,
  • responsive touch controls,
  • browser-based firmware installation.
All game names, interfaces, visual elements, procedural symbols, and implementation code were created specifically for this project. No commercial game assets are included.
Final Result
CrowPanel Pocket Arcade turns a small ESP32 touchscreen into a complete standalone gaming device with six different games.
It combines quick arcade sessions, puzzles, reaction challenges, solo gameplay, and local multiplayer in one compact project.
Small screen. Six games. No internet required. Pure pocket-sized arcade fun.
  • GITHUB
545
12
  • Like( 12 )
