Pabec
  • 61 Projects
  • 9 Followers
  • Oct 31,2025
ESP LUA Loader
ESP LUA Loader
ESP_i2c_OLED_Test2.ino
//This code is a mess right now but does show something on the display
//Oled Display i'm using has an i2c address of 0x0C
//ESP-01 has only two I/O pins, 0=SDA, 2=SCL
//    OLED Test Code                                        //
#include <Wire.h>
//---------------FONT + GRAPHIC-----------------------------//
#include "data.h"
// OLED I2C bus address
#define OLED_address  0x3c
 // Set SDA & SCL for ESP8266 to:
 #ifdef ARDUINO_ESP8266_ESP01
  Wire.pins(0, 2); //0=SDA, 2=SCL, 2 also =LED
 #endif
  // Initialize I2C and OLED Display
  Wire.begin();
  init_OLED();
  reset_display();           // Clear logo and load saved mode
   for(int i=0;i<128*8;i++)     // show 128* 64 Logo
     SendChar(pgm_read_byte(logo+i));
    delay(8000);
    displayOn();
    clear_display();
   while(1)
    sendStrXY("Oled on",3,0);
    sendStrXY("ESP8266 only!",4,0);
    delay(4000);
    reset_display();
    clear_display();
    delay(1000);
    reset_display();
// Resets display depending on the actual mode.
static void reset_display(void)
  displayOff();
  clear_display();
  displayOn();
// Turns display on.
void displayOn(void)
    sendcommand(0xaf);        //display on
// Turns display off.
void displayOff(void)
  sendcommand(0xae); //display off
// Clears the display by sendind 0 to all the screen map.
static void clear_display(void)
  unsigned char i,k;
  for(k=0;k<8;k++)  //8
    setXY(k,0);
      for(i=0;i<128;i++)     //was 128
        SendChar(0);         //clear all COL
// Actually this sends a byte, not a char to draw in the display.
// Display's chars uses 8 byte font the small ones and 96 bytes
// for the big number font.
static void SendChar(unsigned char data)
  Wire.beginTransmission(OLED_address); // begin transmitting
  Wire.write(0x40);//data mode
  Wire.write(data);
  Wire.endTransmission();    // stop transmitting
// Prints a display char (not just a byte) in coordinates X Y,
// being multiples of 8. This means we have 16 COLS (0-15)
// and 8 ROWS (0-7).
static void sendCharXY(unsigned char data, int X, int Y)
  setXY(X, Y);
  for(int i=0;i<8;i++)  //8
    Wire.write(pgm_read_byte(myFont[data-0x20]+i));
// Used to send commands to the display.
static void sendcommand(unsigned char com)
  Wire.beginTransmission(OLED_address);     //begin transmitting
  Wire.write(0x80);                          //command mode
  Wire.write(com);
// Set the cursor position in a 16 COL * 8 ROW map.
static void setXY(unsigned char row,unsigned char col)
  sendcommand(0xb0+row);                //set page address
  sendcommand(0x00+(8*col&0x0f));       //set low col address  //8
  sendcommand(0x10+((8*col>>4)&0x0f));  //set high col address  //8
// Prints a string regardless the cursor position.
static void sendStr(unsigned char *string)
  unsigned char i=0;
  while(*string)
    for(i=0;i<8;i++)
      SendChar(pgm_read_byte(myFont[*string-0x20]+i));
    *string++;
// Prints a string in coordinates X Y, being multiples of 8.
// This means we have 16 COLS (0-15) and 8 ROWS (0-7).
static void sendStrXY( char *string, int X, int Y)
  setXY(X,Y);
  unsigned char i=0;
  while(*string)
    for(i=0;i<8;i++)
    *string++;
// Inits oled and draws logo at startup
static void init_OLED(void)
  sendcommand(0xa6);            //Set Normal Display (default)
    // Adafruit Init sequence for 128x64 OLED module
    sendcommand(0xAE);             //DISPLAYOFF
    sendcommand(0xD5);            //SETDISPLAYCLOCKDIV
    sendcommand(0x80);            // the suggested ratio 0x80
    sendcommand(0xA8);            //SSD1306_SETMULTIPLEX
    sendcommand(0x2F); //--1/48 duty    //NEW!!!
    sendcommand(0xD3);            //SETDISPLAYOFFSET
    sendcommand(0x0);             //no offset
    sendcommand(0x40 | 0x0);      //SETSTARTLINE
    sendcommand(0x8D);            //CHARGEPUMP
    sendcommand(0x14);
    sendcommand(0x20);             //MEMORYMODE
    sendcommand(0x00);             //0x0 act like ks0108
    sendcommand(0xA0 | 0x1);      //SEGREMAP   //Rotate screen 180 deg
    //sendcommand(0xA0);
    sendcommand(0xC8);            //COMSCANDEC  Rotate screen 180 Deg
    //sendcommand(0xC0);
    sendcommand(0xDA);            //0xDA
    sendcommand(0x12);           //COMSCANDEC
    sendcommand(0x81);           //SETCONTRAS
    sendcommand(0xCF);           //
    sendcommand(0xd9);          //SETPRECHARGE
    sendcommand(0xF1);
    sendcommand(0xDB);        //SETVCOMDETECT
    sendcommand(0x40);
    sendcommand(0xA4);        //DISPLAYALLON_RESUME
    sendcommand(0xA6);        //NORMALDISPLAY
  clear_display();
  sendcommand(0x2e);            // stop scroll
  //----------------------------REVERSE comments----------------------------//
  //  sendcommand(0xa0); //seg re-map 0->127(default)
  //  sendcommand(0xa1); //seg re-map 127->0
  //  sendcommand(0xc8);
  //  delay(1000);
  // sendcommand(0xa7);  //Set Inverse Display
  // sendcommand(0xae); //display off
  sendcommand(0x20);            //Set Memory Addressing Mode
  sendcommand(0x00);            //Set Memory Addressing Mode ab Horizontal addressing mode
  //  sendcommand(0x02);         // Set Memory Addressing Mode ab Page addressing mode(RESET)
   setXY(0,0);
More Code on GitHub: https://github.com/mike-rankin/ESP_LUA_Loader.This is GitHub account: https://github.com/mike-rankin where you will explore more excellent projects. He is a good DIY maker who designs custom ESP32 IoT projects using Altium Designer, Arduino IDE and Fusion360. Welcome everyone to follow.
ESP LUA Loader
16.2k
14
  • Like( 14 )
