Coder9
  • 5 Projects
  • 0 Followers
  • Nov 15,2026
Display projects for ESP32
Some display projects for ESP32
  • ESP32-C3 MCU Board
  • CrowPanel Advanced 7inch |ESP32-S3
    Elecrow
    X 1 fenxiang
1) PC resource panel
with a display, multimerter and ESP32, you can create a custom PC resource monitor. First, you would ahve to dissassemble the multimeter, and connect the ESP32 to the multimeter 7-segment display output. A Raspberry Pi pico communicating to the ESP over I2C may be good, for the extra GPIO. After you have connected the ESP32 to the multimeter, that's part one done.
Part 2 is connecting the Multimeter power lines and also the power testing lines to the Power supply. If you can find a 5-50V buck-boost converter, you can power the multimeter, and another one set at 5V for the ESP. Then, connect the testing leads to the power supply. With some programming, you're set to make this build.
2) Home assistant wireless panel
This is actually will be able to control lights, and all sorts with a touch display panel, ESP32s to spare, and also some ti me and patience.
1. Set up the OS panel
You can make your own OS, and so on, but how to transmit data? You can do this via WiFi. You will need an ESP32, with WiFi capabilities, and another of the ESP32. One, sends the data via WiFi, and it will be recieved by the next ESP32.
3) ESP32 microcomputer
the thing is, with an ESP32 and a display, you can make a microcomputer. Use the UART for a custom keyboard, have a custom keyboard at the ready, and you have a terminal. This can be incredibly useful for projects, and even you can make you terminal an ESP32 flasher.
Outroduction
Well, the projects are endless. From possibly PCB SATA connections using SPI-USB-SATA, anything. If you can dream it, you can build it.
23
11
  • Like( 11 )
