FUSION AUTOMATE
  • 20 Projects
  • 8 Followers
  • Oct 27,2026
ESP32 NAS File Server - 2.8inch ESP32 Solo Miner LCD Display
Turn an Elecrow CrowPanel 2.8-inch ESP32 display into a Wi-Fi microSD file server with a browser-based file manager, live storage status, and captive-portal setup.
Overview
A lightweight network-attached storage (NAS) file server for the Elecrow 2.8-inch ESP32 CrowPanel / ESP32 Solo Miner LCD display. The ESP32 serves files from the built-in microSD card over Wi-Fi and uses the TFT to show connection and storage status. Manage files from a web browser on the same local network.
  • Browser-based file manager for listing, uploading, downloading, and deleting files and creating folders.
  • Drag-and-drop web UI with upload progress.
  • Captive-portal Wi-Fi provisioning and automatic access-point fallback when home Wi-Fi is unavailable.
  • TFT status screen showing Wi-Fi mode, IP address, SD total/free space, and web URL.
  • SD mount retry and visual error handling; Wi-Fi reconnect with AP fallback.
  • Optional default Wi-Fi credentials from a local, git-ignored secrets.h.
  • OTA firmware updates via ArduinoOTA.
  • Path validation to help prevent directory traversal.
Hardware
  • Elecrow 2.8-inch ESP32 Solo Miner LCD Display / CrowPanel variant (ESP32-WROOM-32)
  • 320 × 240 ILI9341V TFT and built-in microSD slot
  • FAT32-formatted microSD card and USB data cable
  • 2.4 GHz Wi-Fi network for normal operation
Build and flash with PlatformIO (recommended)
  1. Install Visual Studio Code and the PlatformIO IDE extension, or install PlatformIO Core.
  2. Open the PlatformIO folder containing platformio.ini.
  3. Optionally copy include/secrets.h.example to include/secrets.h, then set your own default SSID/password. Keep this private file out of source control.
  4. Build with pio run, connect the board over USB, and upload with pio run -t upload.
  5. Use pio device monitor at 115200 baud to view startup and diagnostics.
First boot and access
  1. Insert a FAT32 microSD card and power the board.
  2. If no Wi-Fi credentials are saved, connect to the open NAS-Setup access point and browse to http://192.168.4.1.
  3. Enter your home Wi-Fi details in the setup portal. After the device connects, note the IP shown on the LCD.
  4. Open http://<device-IP>/ from a phone or computer on the same LAN. Copy index.html to the SD card root if you want the richer drag-and-drop file manager.
Hardware pin and bus notes
The microSD card uses VSPI (MOSI 23, MISO 19, SCK 18, CS 5). The TFT uses a separate HSPI bus (MOSI 13, SCLK 14, CS 15, DC 2, backlight 27). PlatformIO configures TFT_eSPI through build flags, including USE_HSPI_PORT, so the display and SD card do not contend for the same SPI bus.
Security notes
The setup access point is open by default, and the file server provides upload/delete access without authentication. Use it only on a trusted local network, avoid exposing it to the internet, and never use sensitive Wi-Fi credentials as defaults. OTA updates are also enabled when connected to Wi-Fi.
Source and attribution
Project repository: https://github.com/papercodeIN/Elecrow. The project was ported from akashdip2001/NAS-with-ESP32. Shared under the MIT License.
  • Project source code (GitHub)
143
25
  • Like( 25 )
