Joel Stuart
  • 12 Projects
  • 4 Followers
  • Dec 15,2025
Go Kart Steering System
A new steering system I designed mainly for Go-Karts.
This is a new steering system that uses gears to turn the wheels. It uses a bevel gear to turn another bevel gear connected to a gear, which turns a belt, which is conncted to another pair of bevel gears, turning a rod, which turns 2 bevel gears on the ends of the rod. These finally turn two bevel gears, connected to the ones on the end, which are conncted to two wheels ????. It sounds complicated in verbal explanation, but if you see the parts in motion it makes sense. It includes polished alluminum parts, and a steering wheel for aesthetics.
817
14
  • Comments( 1 )
  • Like( 14 )
