Luc Paquin
  • 77 Projects
  • 19 Followers
  • Nov 27,2025
Project #16: Sound – Sound Sensor – Mk28
Web
https://www.donluc.com/?p=4609
Facebook
https://www.facebook.com/share/v/16PtbACWTp/
YouTube
https://youtu.be/cInsL_Y37P0
DFRobot
https://learn.dfrobot.com/makelog-315072.html
#DonLucElectronics #DonLuc #SoundSensor #FireBeetle2ESP32E #ESP32 #DFRobot #Display #IoT #Project #Fritzing #Programming #Electronics #Microcontrollers #Consultant
Gravity: Analog Sound Sensor
This Analog Sound Sensor is compatible with Arduino, detects sound intensity, and features improved voltage range and interfaces. Suitable for DIY projects.  Sound Sensor is typically used in detecting the loudness in ambient, the Arduino can collect its output signal and actuate accordingly. You may use it to make some funny interactive works such as a "Clap and Buzz" to find your lost keys.
Gravity: Digital Speaker Module
This speaker module features an 8002 amplifier IC, adjustable volume, digital interface, and compact design, suitable for Arduino projects with voltage range 2.0-5.5 Volt.
DL2511Mk02
1 x DFRobot FireBeetle 2 ESP32-E
1 x Fermion: 2.0" 320x240 IPS TFT LCD
1 x GDL Line 10 CM
1 x Gravity: IO Shield for FireBeetle 2
1 x Gravity: Analog Sound Sensor
1 x Gravity: Digital Speaker Module
1 x Gravity: Digital RGB LED Module
1 x Switch
1 x USB 3.0 to Type-C Cable
DL2511Mk02p
DL2511Mk02p.ino
getDisplay.ino
getEEPROM.ino
getSound.ino
setup.ino
-Programming Language
-IoT
-Robotics
-Automation
-Unmanned Vehicles Terrestrial,  Marine and UAV
-Machine Learning
-Artificial Intelligence (AI)
-RTOS
-Consulting
-Etc...
Follow Us
https://www.donluc.com/luc/
Web: https://www.donluc.com/
Don Luc
615
14
  • Like( 14 )
