Grovety
  • 23 Projects
  • 25 Followers
  • Jun 11,2025
MiniMeteo: Compact Indoor Air Quality Station for CrowPanel
Turn your CrowPanel Advance into a smart indoor air monitor with the EnSens Add-on. Get real-time data on temperature, humidity, pressure, IAQ, CO₂, and VOCs—visualized with trend arrows and color alerts. Easy plug-in setup, open-source firmware, and instant installation.
Based on CrowPanel Advance 2.8" or 3.5" and EnSens Add-on.
This project turns your Elecrow CrowPanel Advance into a smart indoor air quality station. By plugging in the EnSens Add-on module (sold separately), you enable precise real-time monitoring of your indoor environment.
The EnSens Add-on integrates Bosch’s high-precision BME688 sensor and connects directly to the panel through a dedicated interface. It measures:
  • Temperature
  • Humidity
  • Barometric Pressure
  • Air Quality Index (IAQ)
  • CO₂ Equivalent (eCO₂)
  • Volatile Organic Compounds (VOCs)
What’s Displayed on Screen
The dedicated application for CrowPanel displays:
  • Current Temperature, Humidity, and Pressure – along with arrow indicators showing the speed and direction of change.
  • IAQ (Indoor Air Quality Index) – a composite measure of air quality, with a side color scale indicating whether the air is clean, acceptable, polluted, or hazardous.
  • CO₂ and VOC Levels – two key factors affecting comfort and health. These values are shown with color-coded indicators to highlight potentially dangerous levels.
  • Settings Menu – allows switching between Celsius/Fahrenheit and mmHg/hPa units.
Easy to Install, Easy to Customize
The application is available open-source on GitHub: 👉 github.com/Grovety/CrowPanel_MiniMeteo
You can either:
  • Use prebuilt firmware for your screen size (2.8” or 3.5”), or
  • Modify the open-source code to tailor the app to your own needs.
Installation takes less than 2 minutes:
Just download the firmware archive for your panel, unpack it, and run the included installer. It will automatically detect your panel and flash it with the ready-to-use MiniMeteo application.
Add-on installation:
  • https://github.com/Grovety/CrowPanel_MiniMeteo
9.9k
18
  • Like( 18 )
