CrowPanel ESP32 4.3-inch with ESP-IDF
Overview
This example tutorial is a project for controlling the on and off of an LED. It demonstrates how to create a UI and how to control the on and off of an LED through buttons on the screen.
In this tutorial, we will show you how to design the UI with SquareLine Studio, and show you how to upload the code with ESP-IDF.
Hardware Preparation
CrowPanel ESP32 4.3'' HMI Crowtail-LED Dupont-wire
CrowPanel-ESP32-4.3inch CROWTAIL-LED 4-PIN-FEMALE-WIRE
BUYNOW BUYNOW BUYNOW
8
  1. Open the SquareLine Studio and create a project.
    [8
    Note:
    Set the name of the project, set the screen resolution to 480*272, set the color depth to 16bit, and keep other default settings. After setting, click CREATE to create the project.
    SLS-UI-2
  2. After creation, enter the following interface with a blank background.
    SLS-UI-3
  3. In the "Assets" area, click "ADD FILE TO ASSETS" to add custom images or icons.
    Note:
  4. Add background.
    SLS-UI-5
    SLS-UI-6
  5. Add Button widget to control the LED.
    SLS-UI-12
    SLS-UI-13
    SLS-UI-14
    SLS-UI-16
    SLS-UI-17
    SLS-UI-19
    SLS-UI-20
  6. Add events to buttons.
    SLS-UI-21
    Select "clicked" as the trigger condition, select a trigger event in "Action". It will be modified in the generated program to achieve the LED control function.
    SLS-UI-22
    SLS-UI-23
    SLS-UI-24
  7. Export UI files.
    SLS-UI-25
    SLS-UI-26
    Then click "APPLY CHANGES".
    SLS-UI-27
    SLS-UI-28
    SLS-UI-29
    You can click download to download the export UI files we provided.
Build the Project with ESP-IDF
Get Started with ESP-IDF
Please click the card below to learn how to install ESP-IDF. Create a blank project according to the "Get Started with ESP-IDF".
GetStartedWithESPIDF
You can click download to download the complete project we provided. This project can be used directly. You can also create the project by following the tutorial.
Add Libraries
Create a new folder and name the folder 'components'. Add the libraries we provided to this folder.
SLS-UI-36
Please click download to download the libraries we provided.
Setup UI file
Add the UI file we exported earlier in Squareline.
SLS-UI-42
The CMakeList.txt file in the UI file needs to be modified as follows:
SLS-UI-37
Setup main file
The CMakeList.txt file contains the Settings for the library. All required libraries should be included by directory address.
SLS-UI-40
The main program is written in CrowPanel_ESP32_4.3.cpp file.
Library introduction
#include <lvgl.h>
#include <LGFX_driver.h>
#include "ui.h"
#include "Arduino.h"
  • #include <lvgl.h>: Library for UI interaction
  • #include <LGFX_driver.h>: Screen driven library.
  • #include "ui.h":is a custom header file that contain UI-related functions or definitions.
  • #include "Arduino.h": This is the core Arduino header file. It must be included when using the Arduino framework.
Code Explanation
Basic Definition
  • Set the screen cache
LGFX lcd;
// Screen buffer
#define DRAW_BUF_SIZE (480*272 / 8)
lv_color_t draw_buf[DRAW_BUF_SIZE];
static lv_display_t *disp;
  • Touch reading function
// Touch reading function
void my_touchpad_read(lv_indev_t *indev, lv_indev_data_t *data) {
    if (lcd.getTouch(&data->point.x, &data->point.y)) {
      Serial.printf("Touch at: (%ld, %ld)\n", data->point.x, data->point.y);
    } else {
  • Resolution
  // Refresh function
  void my_disp_flush(lv_display_t *disp, const lv_area_t *area, uint8_t *px_map) {
    uint32_t w = lv_area_get_width(area);
    uint32_t h = lv_area_get_height(area);
    lcd.pushImageDMA(area->x1, area->y1, w, h, (lgfx::rgb565_t *)px_map);
    lv_display_flush_ready(disp);
  • Obtain the tick time
  // Get tick time
  uint32_t my_tick() {
    return millis();
Set Up Part
void setup(){
    Serial.begin(115200);
    lcd.begin();
    pinMode(2, OUTPUT);
    digitalWrite(2, HIGH);
    pinMode(38, OUTPUT);
    digitalWrite(38, LOW);
  // Initialize LVGL
  lv_init();
  lv_tick_set_cb(my_tick);
  // Create display
  disp = lv_display_create(480, 272);
  lv_display_set_flush_cb(disp, my_disp_flush);
  lv_display_set_buffers(disp, draw_buf, NULL, sizeof(draw_buf), LV_DISPLAY_RENDER_MODE_PARTIAL);
  // Register input device (touch)
  lv_indev_t *indev = lv_indev_create();
  lv_indev_set_type(indev, LV_INDEV_TYPE_POINTER);
  lv_indev_set_read_cb(indev, my_touchpad_read);
  ui_init();
Main Program Part
void loop(){
    lv_timer_handler();  // LVGL task handling
    delay(10);
// Entry point for ESP-IDF
extern "C" void app_main() {
    setup();
    while (true) {
      loop();
Setup board
ESP-IDF-1
All required configuration options are defined in the "sdkconfig.defaults" file.
ESP-IDF-11
Download the program
Connect the ESP32 Display to the PC and compile the program.
ESP-IDF-12
After confirming the serial port, select the UART mode.
ESP-IDF-13
After the program is successfully downloaded, connect the LED to GPIO_D. Click the ON button on the screen and the LED will turn on. Click the OFF button and the LED will turn off.
example
