Crowtail- Relay
The Crowtail- Relay module is a digital normally-open switch. Through it, you can control circuit of high voltage with low voltage, say 5V on the controller.
Model: CT0008RE
  • High Switching Current
Dimensions(mm):40.0(L)x20.0(W)x17.2(H)
Parameter Description
Operating Voltage 5V
Operating Current 90mA
Relay Life 100,000 Cycle
Max Switching Voltage 120VAC/24VDC
Max Switching Current 3A
Usage
Intelligent Temperature Control Fan
1.Hardware Connection
2.Copy the demo code to your sketch, then upload to Arduino or Crowduino board.You can set a threshold temperature value to control the realy ON or OFF, then control the fan work or not.
Temperature sensor connect to AO
Relay connetct to D5
#include <math.h>
int a;
float temperature;
int B=3975;                  //B value of the thermistor
float resistance;
// Connect the Relay to digital pin D5.
// give it a name:
int Relay = 5;
 // initialize the digital pin as an output.
 pinMode(Relay, OUTPUT);
   a=analogRead(0);
   resistance=(float)(1023-a)*10000/a; //get the resistance of the sensor;
   temperature=1/(log(resistance/10000)/B+1/298.15)-273.15;//convert to temperature via datasheet ;
   delay(1000);
   Serial.print("Current temperature is ");
   Serial.println(temperature);
   if(temperature>20)
         digitalWrite(Relay, HIGH);  //if temperature >20 degree,turn the Relay on,fan working
   else
        digitalWrite(Relay, LOW);//if temperature <=20 degree,turn the Relay off,fan not working
3.When the temperature above 20 degrees,the fan will working.
Resource
