ThinkNode G3-Single Channel LoRaWAN Gateway ESP32-S3 Chip Smart Home, Smart IoT Solutions
ThinkNode G3 is a high-performance, compact LoRaWAN gateway designed for IoT communications by Elecrow. It uses the ESP32-S3 dual-core processor and Semtech SX1262 transceiver, equipped with a 240MHz dual-core main control, integrated Bluetooth, WiFi and optional 4G modules(Not yet released), and can provide flexible network backhaul methods. The SX1262 transceiver, combined with the internal TCXO crystal oscillator, ensures the ultra-long-distance transmission and high-frequency stability of the ThinkNode G3 while maintaining low power consumption. It supports the configuration of US915MHz/EU868MHz/AU915MHz frequencies, supports seamless conversion between LoRa and IP protocols, can efficiently receive LoRa signals and transmit them back to the cloud through multiple networks to achieve stable data interaction. Its simple configuration interface supports quick adjustment of LoRa parameters on mobile phones or PCs, and supports remote firmware upgrades, greatly improving deployment and maintenance efficiency. ThinkNode G3 supports development languages such as MicroPython, C/C++, and is compatible with ESP-IDF and Arduino IDE development environments, providing engineers and technology enthusiasts with extremely high development flexibility and simplifying the secondary development process.
ThinkNode G3 adopts a modern smart home style design and is equipped with a multi-functional fixed base. It supports multiple installation methods, such as wall, plate, and slide rails, to adapt to diverse indoor and outdoor deployment needs. It is widely used in smart cities, smart agriculture, industrial Internet of Things, smart buildings, logistics management, environmental monitoring and other fields. It is a key hub in the Internet of Things communication architecture.
Designed & manufactured by Elecrow, customized requests can be discussed(based on MOQ), you can contact us at service@elecrow.com.
Model ILM13103D
thinknode_g3_lorawan_gateway
Network Topology
ThinkNode_G3_Network_Topology
Hardware Overview
Hardware_overview_Thinknode_G3
Size_of_Thinknode_G3_1
  • Adopts ESP32-S3 240MHz dual-core main control, with SemtechSX1262 LoRa transceiver, supports long-distance, low-power communication.
  • The main frequency is up to 240MHz, with 4M Flash and 384KB ROM storage.
  • The internal TCXO crystal ensures accurate frequency and improves communication stability.
  • Supports WiFi, Ethernet and multiple backhaul methods to meet the needs of different network environments.
  • Provides mobile phone/PC configuration interface, supports parameter adjustment.
  • Support remote firmware upgrade.
  • Compact design and integrates smart home aesthetics, equipped with a multi-functional mounting base, can be flexibly deployed on walls, slides and other scenes.
  • Support MicroPython、C/C++ development languages, and is compatible with ESP-IDF、Arduino IDE development environment.
  • Low power consumption, the maximum working current is about 110mA (MCU+LoRa transceiver)
  • Realizes efficient conversion between LoRa and IP protocols, ensures seamless interaction between devices and cloud data.
Target Group
Agribusiness/Industrial manufacturers/Construction management companies/Logistics service providers/Community organizations/Environmental monitoring/Institutions/Individual consumers/Technology enthusiasts.
Application
Smart Cities/Smart Agriculture/Industrial IoT/Smart Buildings and Home Automation/Logistics and Supply Chain Management/Smart Metering/Environmental Monitoring/Emergency Services and Disaster Response/Consumer Applications
Main Processor (ESP32-S3-WROOM-1-N8R8)
CPU/SoC Equipped with high-performance Xtensa32-bit LX7 dual-core processor
Frequency Up to 240MHz
System Memory 512KB SRAM、8M PSRAM
Storage 4M Flash,384KB ROM
Development language MicroPython、C/C++
Development environment ESP-IDF、Arduino IDE
Network configuration interface Self-developed web console with network and LoRaWAN server configuration, OTA upgrade
Wireless Communication
WiFi Support 802.11 b/g/n, 2.4GHz
Bluetooth Bluetooth Low Energy and Bluetooth 5.0
LoRa SX1262 LoRa Transceiver、US 915MHz/EU 868MHz/AU 915MHz(External antenna)
4G 4G communication (LTE CAT1) (Not yet released, please stay tuned)
Interface
Ethernet port RJ45,10/100Mbps
USB Interface Type-C, debugging, power supply interface
LoRa antenna interface RP-SMA
4G antenna interface RP-SMA(Reserve)
Hardware
Reload Button Device restart, debugging, and factory reset
Status Light Power indicator, LoRa indicator, LINK indicator
Software
Development Language MicroPython、C/C++
Development Environment ESP-IDF、Arduino IDE
Other
Power Input 5V/1A, supports USB or lithium battery power supply
Power consumption 110mA@5V (MCU+LoRa transceiver)
Enclosure Material ABS
Installation Method Back hanging, wall hanging, desktop
Operating Temperature -20~70°C
Storage Temperature -40~80 °C
Relative humidity 10%-95%, @ 40°C (non-condensing)
Size 75*75*30mm(L*W*H)
Net Weight 66g
Gross Weight 210G
Resources
How to buy
Please visit this page to purchase ThinkNode G3 LoRaWAN Gateway .
Support
