Crowtail- I2C Hub
This is an I2C interface expansion board with four 4-Pin I2C interfaces. When the I2C interfaces on the Base shield is not enough, it can provide more extensive IIC pins for your project.This corwtail module is small and simple, if the I2C port of you project is not enough, it's a good choice.
Model: CRT00529H
Multiple connections
Dimensions(mm):40.0(L)x20.0(W)x9.8(H)
Usage
Connect multiple I2C modules Access multiple external I2C modules, because each I2C address is not the same, you can work at the same time, as follows:
Resource
