ESP Terminal 3.5-inch Display PlatformIO Tutorial
Overall¶
This tutorial uses both RGB and SPI versions. Take the Terminal-SPI as an example.
Software Preparation¶
First download Visual Studio Code on https://code.visualstudio.com/. Choose the version that is compatible with your computer system and download it ![]()
Open VSCode and click on Extension, search for Python and install. ![]()
Search for PlatformIO and install it. ![]()
Create new projects¶
Click on the PlatformIO icon, click the quik access "Open", then click "+New Project" ![]()
Add the project name. The board select "ESP32-S3-DevKitC-1-N8(8 MB QD, No PSRAM)", framework select Arduino
The main part of the program will be written in main.cpp ![]()
Download the lvgl and LovyanGFX library ![]()
We can see that the library has been added successfully!
Configure the LVGL library¶
Right-click the lvgl and open in files explorer
Move the demos and examples folder to src folder ![]()
Place the lv_conf.h file under the esp32-s3-devkit-1 directory ![]()
Put the FT6236.cpp file into the /src folder ![]()
Put the FT6236.h file in the /include folder ![]()
Compile and upload the code¶
After the configuration is complete, write the code in main.cpp. ![]()
Then we can upload the code to the board. ![]()
