CrowPanel Advanced 10.1inch |ESP32-P4 HMI AI Display 1024x600 IPS Touch Screen with WiFi 6 Compatible with Arduino/LVGL
ModelDHE04310D
esp32-p4_10.1inch_display_1
Schematic:
esp32-p4_10.1inch_display_2
SPK Output audio signals to connect to speakers. The main board comes with a power amplifier chip circuit. PH2.0-2P
PWR Power LED.
CHG Charging LED
boot
UART1 Builds communication between Logic modules, including the serial communication module and the print module. PH2.0-4P
I2C Builds communication between Logic modules, including the serial communication module and the print module. PH2.0-4P
UART3-IN Input power supply and serial communication functionality XH2.54-4P
BAT Connect the lithium battery. (with battery charging circuit) PH2.0-2P
10.1-inch HMI port pin number Electrical Characteristics
UART1 RX(IO48); TX(IO47) ; Output voltage: 3.3V Output current: 1A max. Use: Power supply output and communication.
UART3-IN RX(IO33); TX(IO34) ; Output voltage: 3.3V Output current: 1A max. Use: Power supply output and communication.
I2C SDA(IO45); SCL(IO46) ; Output voltage: 3.3V Output current: 1A max. Use: Power supply output and communication.
SD Card SD1_CMD(IO44); SD1_SCK(IO43); SD1_D0(IO39); CS(GND) Maximum output current: 20mA Signal type: 3.3V logic level, digital control signal
LCD Backlight LCD_BK_POWER(IO29);
LCD_BK_EN(IO31)(PWM)
PDM MIC MIC_MCLK1(IO24);MIC_SD1(IO25) Maximum output current: 20mA Signal type: 3.3V logic level, digital control signal
SPK Cavity Speaker YZ3020/3020 Square/4Ω 3W
BAT Input voltage: 3.7–4.2 V,Maximum intput current: 430mA
ESP32-P4 10.1 inch and IPS Display Wiring Pins:
**DSI = Display Serial Interface**is a high-speed, low-power display interface standard defined by the MIPI Alliance, most commonly used in smartphones, tablets, Raspberry Pi devices, and embedded Linux systems.
P4-7-sch-1
DSI Pin connection
DSI_DATAN0--IO40
DSI_DATAN0--IO39
DSI_DATAN0--IO36
DSI_DATAN0--IO35
DSI_CLKN--IO37
DSI_CLKP--IO38
DSI_REXT--IO34
ESP32-P4 and Touch Driver Wiring:
i2c address: 0x5D/0x14.(The INT pin level during reset of the GT911 touch chip determines the device address.)
INT Low Level(0x5D);
INT High Level(0x14).
P4-10.1-sch-2
Pin connection
I2C1_SCL(IO46)
I2C1_SDA(IO45)
INT_TP(IO42)
RESET_TP(IO40)
ESP32-P4 and wireless module wiring pins:
Output voltage: 3.3V Output current: 1A max. Use: The power supply communicates with the wireless module.
P4-10.1-sch-3
Pin connection
#define RADIO_GPIO_CLK 8
#define RADIO_GPIO_MISO 7
#define RADIO_GPIO_MOSI 6
#ifdef CONFIG_BSP_SX1262_ENABLED
#define SX1262_GPIO_BUSY 9
#define SX1262_GPIO_IRQ 53
#define SX1262_GPIO_NRST 54
#define SX1262_GPIO_NSS 10
#ifdef CONFIG_BSP_NRF2401_ENABLED
#define NRF24_GPIO_IRQ 9
#define NRF24_GPIO_CE 53
#define NRF24_GPIO_CS 54
ESP32-P4 and Audio out:
P4-10.1-sch-4
Pin connection
#define AUDIO_GPIO_LRCLK    21   // GPIO pin number for LRCLK (Left-Right Clock)
#define AUDIO_GPIO_BCLK     22   // GPIO pin number for BCLK (Bit Clock)
#define AUDIO_GPIO_SDATA    23   // GPIO pin number for SDATA (Serial Data)
#define AUDIO_GPIO_CTRL     30   // GPIO pin number for audio amplifier control
Program Download Tutorial Video(Click on the image):
[][video]Tutorial Video
Introduction to UART 0 and USB 2.0:
Program downloads require the use of UART 0.
uart0+usb2.0-1
Note: Turn on the switch before use. Slide the POWER switch to the ON position.
uart0+usb2.0-3
If the program utilizes screen functions, power consumption will reach 8-10 watts. If powered solely by the computer's USB port, insufficient power may cause the screen to go black. It is necessary to connect a USB 2.0 port simultaneously for power supply.
uart0+usb2.0-2
If the UART0 connection does not display a serial port number, it may be due to missing serial port drivers. Download the CH341 serial port drivers and retest the connection.
Serial Port Driver for Mac:https://www.wch.cn/downloads/CH34XSER_MAC_ZIP.html
Regarding situations where serial ports remain inaccessible after installing drivers on a Mac, the following settings must be configured on the Mac:
  1. After installing the CH341 serial port driver, navigate to System Preferences.Click Login Items & Extensions.
mac-uart-1
2.Click Driver Extensions.
mac-uart-2
3.Click Open, then click Done to save the settings.
mac-uart-3
mac-uart-4
USB 2.0:
USB 2.0 (Universal Serial Bus 2.0) is a common universal serial interface standard used to connect computers with various peripherals.
Its maximum transfer rate is 480 Mbps (High-Speed mode), representing a significant improvement over USB 1.1. This enables it to meet the data transfer needs of devices such as keyboards, mice, USB flash drives, printers, and webcams. USB 2.0 supports hot-plugging and plug-and-play for ease of use, while also providing 5V power supply (up to 500 mA) to peripherals.
Note: The shipped firmware does not include USB functionality. For those requiring USB features, please refer to our USB functionality course in Lesson 6.
NOTE:The firmware for the C6 module is pre-programmed at the factory and cannot be directly reprogrammed via P4.
Platforms Supported
Compile Environment Configuration:
Vs code Installation
(1) First, download Visual Studio Code from https://code.visualstudio.com/. Select the version compatible with your computer's operating system and download it.
P4-idf-1
(2) Double-click to install Visual Studio Code software, and simply proceed with the default installation throughout.
P4-idf-2
P4-idf-3
P4-idf-4
P4-idf-5
(3) Open Visual Studio Code, click on ‘Extensions’, search for Python, and install it.
P4-idf-6
(4) Search for ESP-IDF and install it.
The IDF version must be 5.4.2 or higher.
P4-idf-7
(5) Install the ESP-IDF tools.
P4-idf-8
(6) Select version 5.4.2 and configure the storage location.
P4-idf-9
(7) Awaiting installation.
P4-idf-10
(8) Installation successful.
P4-idf-11
Elecrow-HMI-UI-contest
Courses on Different Platforms:
AI Voice Chat Robot SquareLine Studio Arduino
ESP32-P4-HMI-AI-Voice-Chat-Robot SquareLineStudio-Logo Arduino
View Tutorials GetStarted GetStarted
ESPHome ESP-IDF
Arduino ESP-IDF-Logo
Resources
How to buy
Please visit this page to purchase CrowPanel Advanced 10.1inch ESP32-P4 HMI AI Display.
Support
