3. Use SquareLine Studio and LVGL libraries to create a UI interface to light the lights
1. Introduce LVGL
2
2.Install SquareLine Studio
2.1 Installation Guide
3
Download the version 1.4.0
4
5
Click install.
6
Wait for installation.
7
Installation finish.
8
9
2.2 Software Function Introduction
Open the software
10
11
12
13
Note: Please select the corresponding resolution and color depth according to the screen specifications.
14
①Toolbar, including File, Export, and Help. Basic file operation bar, create or open files, export UI files and other operations. Click help and there are related introductory documents.
②Screen bar, the project screen will be listed here.
③Widget area, all widgets are here and can be selected and used according to project needs.
④Hierarchy area, it will show every widget used in each screen.
⑤This area shows the actual display effect, you can adjust the widgets or screen here.
⑥Material column, the added materials are displayed here.
⑦Setting bar, where you can make basic settings for each part, including the basic attributes and trigger operations of the part.
⑧Theme bar, different themes can be set.
3 Use SquareLine Studio to create UI control interfaces
15
16
Here, I take a 2.8-inch screen as an example. After determining the resolution, I fill it in
The version of LVGL we are using is 8.3.11.
17
18
19
Click the link below to download the image materials for this course.
Image material link:
https://github.com/Elecrow-RD/CrowPanel-Advance-2.8-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-320x240/tree/master/example/V1.1_and_V1.2/Arduino_Code/lesson-03
The table_lamp image sizes are available for 3.5-inch, 4.3-inch, 5.0-inch, and 7-inch screens.
22
23
24
25
26
27
28
29
30
31
32
33
4 Add functions to the buttons to enable them to turn on and off lights
Select 'event' to add in the right sidebar
34
35
After selecting, click ADD.
36
37
After adding, run
38
39
5 UI interface design completed, exporting UI files for easy use in subsequent code
Click on Project Setting
40
Set export path
41
42
Complete the setup and export file
43
Copy and paste the exported code into the code folder we need to open
44
45
Then double-click 2_8LVGL.ino and open it using Arduino IDE.
You can click the link below to download the corresponding version of the code for this lesson. Code link:
2.8-inch / 2.4-inch V1.0:
https://github.com/Elecrow-RD/CrowPanel-Advance-2.8-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-320x240/tree/master/example/V1.0/Arduino_Code
6 Connect the light bulb and add code to control the light bulb to turn on and off
Connect the light bulb at the UART1 interface
46
Observing the schematic diagram of this size, it is known that the pin for UART1 to control the light bulb to turn on and off is 18
47
48
So in the code, set pin 18 as the output mode.
A large-sized screen requires setting 19 pins as the output mode.
The code for size 2.8 is the same as the code for size 3.5, only the UI display file configured is different
49
And add the function of turning on and off the light bulb in the ui_ event. c file.
(When the On button is clicked, the light is on; when the Off button is clicked, the light is off)
50
7 Configure the code running environment and upload the code
(!! Before uploading the code, please use different library files according to the size you are using. You can review the content of Lesson 1)
51
52
So you can see the UI interface you just designed
53
You can click the On and Off buttons to control the on/off of the lights
54
55
8 Code presentation
2.8-inch / 2.4-inch
Here is a new program (pwn version) for adjusting the backlight, which allows you to control the screen brightness by using PWM. Here is the program to adjust the brightness of the backlight:
// Select PWM channel
int pwmChannel = 0;
int pwmFreq = 5000;  // 5kHz
int pwmResolution = 8; // 8-bit resolution(0-255)
int pwmPin = 38;  // Set the pins, assuming you are using GPIO38
  // Configure PWM channels
  ledcSetup(pwmChannel, pwmFreq, pwmResolution);
  // Connect the PWM signal to the specified pins
  ledcAttachPin(pwmPin, pwmChannel);
  // Adjust PWM duty cycle  (0-255)
  for (int dutyCycle = 0; dutyCycle <= 255; dutyCycle++) {
    ledcWrite(pwmChannel, dutyCycle); // Setting the Duty Cycle
    delay(100); // Delay to visualize changes
new-1
Library file link:
CrowPanel-Advance-2.4-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-320x240/example/V1.1_and_V1.2/Arduino_Code/libraries at master · Elecrow-RD/CrowPanel-Advance-2.4-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-320x240
