ThinkNode M9 Meshtastic Communication Terminal with Full Keyboard
Document version: 2026-08-26
Applicable device: Elecrow ThinkNode M9 V1.0
Applicable software: the Meshtastic firmware and on-device interface shown in this guide. Menu names and behavior may change with firmware updates.
Table of Contents
1. Product Introduction
1.1 Product Overview
ThinkNode M9 is a standalone Meshtastic communication terminal in a phone-like form factor. Its display, full keyboard, LoRa radio, positioning, battery, and local user interface allow it to exchange messages and locations without requiring a phone for everyday use. A phone can still be connected when the Meshtastic app is needed for advanced configuration or management.
The device integrates an ESP32-S3, Semtech LR1110, GNSS, a 2.4-inch color LCD, microSD storage, RTC, magnetic and motion sensors, Wi-Fi, Bluetooth, a buzzer, and a dedicated ESP32-S2 keyboard controller.
Typical uses include:
  • Off-grid text communication where cellular service is unavailable;
  • Hiking, camping, event coordination, and emergency preparedness;
  • Meshtastic group-channel and direct-message communication;
  • GNSS positioning, location sharing, and offline map viewing;
  • Node, signal, route, and packet diagnostics from the device.
1.2 Safety Information and Package Contents
1.2.1 Safety Information
  1. Install a LoRa antenna matched to the hardware frequency band before powering on or transmitting.
  2. Select the correct Meshtastic Region for the country or territory in which the device is used. Frequency, bandwidth, duty cycle, and transmit power must comply with local regulations.
  3. Do not share private channel keys, Bluetooth pairing codes, Wi-Fi credentials, or precise location data publicly.
  4. Keep the battery adequately charged during firmware updates. Do not disconnect power or remove the microSD card while an update or storage operation is in progress.
  5. Install only firmware explicitly built for ThinkNode M9. A generic ESP32-S3 Meshtastic image may use a different pin map and can leave the screen, radio, keyboard, GNSS, or power controls unusable.
  6. The LCD, microSD card, and LR1110 share one SPI bus. Custom firmware must keep all non-target chip-select signals inactive.
1.2.2 Package Contents
  • ThinkNode M9 unit;
  • USB-C data/charging cable;
  • ThinkNode M9 starter card;
  • Antenna and other accessories included with the purchased bundle.
Check the actual sales package against the seller's packing list, as bundle contents may vary.
1.3 Hardware Architecture and Specifications
1.3.1 Key Specifications
Item ThinkNode M9 V1.0
Main controller ESP32-S3-R8, dual core, up to 240 MHz
Keyboard controller ESP32-S2
LoRa transceiver Semtech LR1110
GNSS ATGM336H-5NR32 / BM72A
Display 2.4-inch color TFT LCD, 320 × 240
RTC PCF8563
Magnetic sensor QMC6309
Motion sensor QMI8658B
Onboard flash ZD25Q128, 128 Mbit (16 MB) NOR Flash
Storage expansion microSD/TF
Wireless connectivity 2.4 GHz Wi-Fi, Bluetooth, LoRa
Battery 2300 mAh rechargeable lithium battery
Charging/data USB-C
The source manual states "16GB Storage." The V1.0 schematic identifies a ZD25Q128 device, which is 128 Mbit (16 MB). Storage available to the user can also depend on the installed microSD card.
1.3.2 Hardware Block Diagram
USB-C -- CH340K ------>|                   |<------ Wi-Fi / Bluetooth
                       |   ESP32-S3-R8 U9   |
GNSS UART/PPS -------->|                   |<-- I2C --> RTC
                       |                   |<-- I2C --> QMC6309 + QMI8658B
                  shared SPI: SCK/MOSI/MISO
                 LR1110        LCD          microSD
                 own NSS       own CS       own CS
ESP32-S2 U10 <---- SDA/SCL + WAKEUP ----> ESP32-S3 U9
      +---- keyboard matrix, shortcut keys, and keyboard LED
1.4 Official Resources
2. Product Pinout
2.1 Main ESP32-S3 GPIO Summary
On the ESP32-S3 symbol, MTCK/MTDO/MTDI/MTMS correspond to GPIO39/GPIO40/GPIO41/GPIO42; SPICLK_P/SPICLK_N correspond to GPIO47/GPIO48; and XTAL_32K_P/XTAL_32K_N correspond to GPIO15/GPIO16.
Schematic Net ESP32-S3 GPIO Purpose
IO0_BOOT GPIO0 Main-controller BOOT
5V_TEST GPIO1 5 V detection/test net
GPS_TX GPIO2 Main controller receives GNSS TX
GPS_RX GPIO3 Main controller transmits to GNSS RX
1PPS_TEST GPIO4 GNSS 1PPS
GPS_RST1 GPIO5 GNSS reset control
SCL GPIO6 RTC/sensor I2C SCL
SDA GPIO7 RTC/sensor I2C SDA
DONE GPIO8 Power/charging status net
BUZZER_EN GPIO9 Buzzer enable
GPS_ON/OFF GPIO10 GNSS on/off control
GPS_EN GPIO11 GNSS power enable
ESP32_WAKEUP GPIO12 Keyboard coprocessor wakes main controller
BAT_ADC GPIO13 Battery-voltage ADC
LCD_RESET GPIO14 LCD reset
LCD_RS GPIO15 LCD RS/DC
LCD_CS GPIO16 LCD chip select
BL_EN GPIO17 LCD backlight enable
VDD_PERIPH_EN GPIO18 Peripheral power enable
LCD_TE GPIO19 LCD tearing-effect signal
ESP32-2_SDA GPIO20 Keyboard-coprocessor data line
ESP32-2_SCL GPIO21 Keyboard-coprocessor clock line
ESP32_MISO GPIO38 Shared SPI MISO
LR_NSS GPIO39 LR1110 chip select/NSS
ESP32_SCK GPIO40 Shared SPI SCK
LR_BUSY GPIO41 LR1110 BUSY
INTERRUPT GPIO42 LR1110 interrupt
LR_NRESET GPIO45 LR1110 reset
KEY_LED GPIO46 Keyboard-light control net
ESP32_MOSI GPIO47 Shared SPI MOSI
SD_CS GPIO48 microSD chip select
2.2 LR1110 LoRa
LR1110 Signal ESP32-S3 GPIO Description
LR_NSS / DIO1 GPIO39 SPI chip select; LR1110 SPI signals are labeled DIO1-DIO4 in the schematic
ESP32_SCK / DIO2 GPIO40 SPI clock
ESP32_MOSI / DIO3 GPIO47 Controller out/peripheral in
ESP32_MISO / DIO4 GPIO38 Controller in/peripheral out
LR_BUSY / DIO0 GPIO41 Busy status
INTERRUPT / DIO9 GPIO42 Interrupt
LR_NRESET / NRESET GPIO45 Reset
DIO7, DIO8 Not connected to main-controller GPIO Reserved nets in the schematic
2.3 LCD
LCD Signal ESP32-S3 GPIO FPC J6
LCD_RESET GPIO14 1
LCD_RS GPIO15 2
ESP32_SCK GPIO40 3
LCD_CS GPIO16 5
DISPLAY_VDD Power 6, 7
LCD_TE GPIO19 8
ESP32_MOSI GPIO47 9
GND - 10, 13, 14
LCD_A / LCD_K Backlight circuit 11, 12
BL_EN GPIO17 Backlight MOS control; not a direct FPC logic signal
2.4 microSD/TF Card
TF Signal ESP32-S3 GPIO Description
SD_CS / CD-DAT3 GPIO48 Chip select
ESP32_SCK / CLK GPIO40 Shared SPI clock
ESP32_MOSI / CMD GPIO47 Shared SPI MOSI
ESP32_MISO / DAT0 GPIO38 Shared SPI MISO
SD_3V3 - Card power
SPI rule: before initializing or accessing a peripheral, ensure that only the target peripheral's CS is low among LR1110 NSS, LCD CS, and SD CS. Keep all other CS signals high.
2.5 GNSS
GNSS Signal ESP32-S3 GPIO Description
GPS_TX GPIO2 GNSS TX → ESP32 RX
GPS_RX GPIO3 ESP32 TX → GNSS RX
1PPS_TEST GPIO4 Pulse per second
GPS_RST1 GPIO5 Reset control
GPS_ON/OFF GPIO10 Module ON/OFF
GPS_EN GPIO11 Power enable
GPS_BAT Backup power Preserves ephemeris/RTC state
2.6 RTC and Sensors
Module Bus/Signal ESP32-S3 GPIO Notes
PCF8563 RTC SCL GPIO6 RTC I2C net
PCF8563 RTC SDA GPIO7 RTC I2C net
QMC6309 3D_SCL GPIO6 through R44 Shares sensor I2C bus with QMI8658B
QMC6309 3D_SDA GPIO7 through R47 Magnetometer
QMI8658B 3D_SCL GPIO6 through R44 Motion sensor
QMI8658B 3D_SDA GPIO7 through R47 CS high and SDO/SA0 grounded; I2C mode
Peripheral power VDD_PERIPH_EN GPIO18 Enables sensor/LCD-related peripheral power
2.7 Keyboard Subsystem (ESP32-S2 U10)
The keyboard matrix is scanned by a separate ESP32-S2. It communicates with the main controller through ESP32-2_SDA/SCL and can wake the main controller.
Function ESP32-S2 GPIO
ROW1 / ROW2 / ROW3 / ROW4 / ROW5 GPIO40 / GPIO42 / GPIO45 / GPIO9 / GPIO19
COL1-COL5 GPIO36 / GPIO37 / GPIO20 / GPIO21 / GPIO11
COL6-COL10 GPIO1 / GPIO2 / GPIO3 / GPIO4 / GPIO5
KEY_INT GPIO12
Main-controller SDA / SCL GPIO7 / GPIO6
Wake line GPIO8
Keyboard light GPIO41
Coprocessor BOOT GPIO0
Dedicated keys are also connected to GPIO18, GPIO10, GPIO39, GPIO38, GPIO33, and GPIO34. In custom firmware, use the keyboard firmware and schematic switch identifiers; do not interpret these as ESP32-S3 GPIO values.
2.8 Other Hardware Signals
Function GPIO/Device Description
Buzzer GPIO9 BUZZER_EN Controlled through a driver transistor
Battery monitoring GPIO13 BAT_ADC Routed to ADC through a divider and filter
USB-UART CH340K U3 Serial communication and maintenance
RTC backup PCF8563 + RTC_3V3 Powered by the backup-power net
Charging LGS4056HDA-4.35 U6 Schematic charging-current formula: I=1000/R
3. Meshtastic Operation
3.1 Controls and First Start
3.1.1 Before Power-On
  1. Install the correct antenna.
  2. Charge the battery using USB-C.
  3. Power on the M9 and wait for the Meshtastic home page.
  4. Confirm the Region before transmitting. Select the legally applicable region, not merely the region shown in the screenshots.
  5. For communication between devices, ensure that Region, modem preset, frequency slot/override, and channel settings are compatible.
3.1.2 Button Functions
Button Meshtastic Function
Home Return to the Home page
Chat Open the chat page
Messages/Menu Open the chat dialog box
Navigation Up/Down/Left/Right Move the cursor, highlight an item, scroll, or pan the map
Navigation center Confirm or open the highlighted item
Back Return to the previous level
Map Open the map page
Positioning Send a temporary position ping; hold for about 3 seconds to enable or disable GNSS
Reset Restart the device
Full keyboard Enter text; press Enter to send where supported
The exact shortcut behavior may vary by firmware version. Follow labels shown on the current screen when they differ from this table.
3.2 Home Page
The Home page is a vertically scrollable status dashboard. The following screenshots show consecutive parts of the same page.
Meshtastic Home page message, node, radio, and signal status
Meshtastic Home page alert, coordinates, and Wi-Fi status
Meshtastic Home page MQTT, FTP, microSD, memory, and QR information
Item Description and Operation
Envelope Shows unread messages; select it to enter chat
Nodes online Shows nodes with previous communication records; select it to open the node list/filter page
Time Select to toggle between current time and device uptime
LoRa frequency/region Displays active radio information; the screenshot is an example only
SNR / RSSI Signal-to-noise ratio and received-signal-strength indicators
Notification Select to change the message-alert mode
Coordinates Displays GNSS coordinates; press and hold to enable or disable GNSS
Wi-Fi Press and hold to enable/disable Wi-Fi and open connection controls; map data can be downloaded after connection
MQTT Press and hold to enable or disable MQTT when configured
FTP Press and hold to enable or disable the FTP server
SD card Shows whether a microSD card is detected
Heap / LVGL Select to show or hide memory and graphics information
QR code Select to display the device QR code
RSSI and SNR describe a received packet or active link sample; they are not a guarantee that a new message has been delivered end to end.
3.3 Node List
Meshtastic node list
The node list shows Meshtastic nodes heard by this device. Depending on the information advertised by a node, an entry can include its long/short name, last-heard time, battery or power state, utilization, and other telemetry.
  • Select a node once to view its available details.
  • Press and hold a node to begin a direct message when supported by the current firmware.
  • A node shown as online or recently heard has transmitted a packet received by the mesh; it does not mean that the node is currently reachable in both directions.
  • Stale entries remain in the node database until they expire or are removed.
3.4 Group Channels and Chat
3.4.1 Group Channels
Meshtastic group-channel list
The Group Channels page lists configured channel slots. Select a channel to open its conversation. Channel interoperability depends on the complete channel configuration, not the displayed name alone.
For two devices to communicate on an encrypted channel, they must use compatible radio settings and the same channel name/key configuration. Share channel URLs or QR codes only through a trusted method because they may contain the encryption key.
3.4.2 Chat Window
Meshtastic chat window
  1. Open a group channel or direct-message conversation.
  2. Select the text field and enter the message with the full keyboard.
  3. Press Enter or select the on-screen send control.
  4. Wait for the message state to update. A locally displayed outgoing message is not by itself proof of remote delivery.
Keep messages concise. LoRa has limited airtime and throughput, and long messages may be split into multiple packets. Avoid repeatedly sending the same message when the channel is busy.
3.5 Map and Positioning
Meshtastic locations map
The map displays local or received Meshtastic positions over offline/online-downloaded tiles.
  • Use the navigation keys to move the map cursor.
  • Press Sym + O to zoom in.
  • Press Sym + I to zoom out.
  • Press and hold the navigation-center key to open map settings.
  • In map settings, use the top control for brightness and the bottom control for contrast.
  • Use the Positioning key or the map control to return to the device position when a valid GNSS fix is available.
Maps are preloaded on the factory microSD card when included with the product bundle. The firmware can also download map data while connected to Wi-Fi. If a replacement card is used, follow the directory and file-format requirements of the installed M9 firmware.
3.5.1 Obtaining a GNSS Fix
  1. Move outdoors with a clear view of the sky.
  2. Enable GNSS and keep the device stationary.
  3. Wait for valid coordinates and a current fix; a cold start may take several minutes.
  4. Verify that the displayed position is current before sending a location ping.
GNSS is not required for text messaging. Position packets can reveal sensitive location data, so review channel membership and position settings before enabling automatic sharing.
3.6 Settings and Tools
3.6.1 Settings
Meshtastic Settings tab
The Settings tab exposes common device and Meshtastic configuration, including user name, Region, modem preset, primary channel, device role, and Wi-Fi. Scroll to reach additional options such as alerts, language, reset, backup/restore, reboot/shutdown, and legal information.
Meshtastic additional settings and Reboot Shutdown
Changes take effect only after selecting OK. Some changes require a restart. Record the original settings before changing radio or channel parameters.
3.6.2 Tools
Meshtastic Tools tab
Tool Function
Mesh Detector Periodically sends node-information requests to detect nearby nodes
Signal Scanner Monitors signal strength for a selected node to assist with placement and testing
Trace Route Performs route tracing for a selected node
Statistics Breaks down received packets by type
Packet Log Shows transmitted and received packet records
Diagnostic tools create radio traffic. Use them sparingly, especially on busy meshes or in regions with strict duty-cycle limits.
3.7 Connect to the Meshtastic App
The M9 works independently, but the official Meshtastic app can be used for configuration, channel management, and node information.
  1. Install the official Meshtastic app from the downloads page, Apple App Store, or Google Play.
  2. On the M9, open Settings & Tools → Settings → Reboot / Shutdown.
Select Reboot Shutdown in Settings
  1. Select the Bluetooth icon on the restart-mode page.
Select Bluetooth restart mode
  1. After restart, the M9 displays Programming mode and a temporary pairing number. To leave Bluetooth programming mode, press and hold the navigation-center key.
M9 Bluetooth programming-mode pairing number
  1. Open the Meshtastic app, choose Bluetooth, and select the M9 from Available devices.
Select the M9 in the Meshtastic app
  1. Enter the pairing number currently shown on the M9, then confirm pairing.
Enter the M9 pairing number
  1. When pairing is complete, the app shows the connected device and signal strength.
M9 connected in the Meshtastic app
The pairing number in these screenshots is only an example. Always enter the number displayed by the device being paired. If the phone has an old pairing record, remove/forget it in both the Meshtastic app and the operating-system Bluetooth settings before trying again.
3.8 Radio, Channel, and Role Configuration
3.8.1 Region and Modem Preset
  • Region applies the frequency plan and regulatory limits for a geographic jurisdiction. Select the location where the device is operating.
  • Modem Preset controls LoRa bandwidth, spreading factor, coding rate, and related timing. Devices intended to communicate directly must use compatible settings.
  • Frequency slot/override must remain compatible across the mesh. Leave advanced frequency overrides at their defaults unless the network plan requires otherwise.
The screenshots show EU_868, 906.875 MHz, and LONG_FAST examples. They are not globally applicable settings. Never copy a screenshot's Region or frequency without checking local rules and the hardware band.
3.8.2 Channels
Meshtastic supports a primary channel and additional secondary channels. The channel name is descriptive; the pre-shared key provides confidentiality. For successful communication, participating devices need the same relevant channel configuration and compatible radio settings.
  • Treat channel QR codes and URLs as secrets if they contain private keys.
  • Do not publish private position or telemetry data to a public/default channel.
  • When a member should no longer have access, rotate the channel key and redistribute the new configuration securely.
3.8.3 Device Role
The CLIENT role is suitable for normal handheld use. Other roles change routing and power behavior. Select a router/repeater-style role only for a deliberately installed, continuously powered node with suitable placement and a configuration that follows current Meshtastic guidance. Using routing roles on every handheld can increase mesh congestion rather than improve coverage.
3.9 Firmware, Storage, and Maintenance
3.9.1 microSD and Maps
Use a reliable microSD card formatted as required by the current M9 firmware. Back up factory map data before replacing or reformatting the card. A missing or unreadable card can affect offline maps, logs, backups, and other storage-backed functions while basic LoRa messaging may continue to work.
3.9.2 Backup and Restore
Use Settings → Backup & Restore before major configuration changes or firmware updates. Protect backups because they can contain network names, channel configuration, and keys. After restoring, check Region and channel settings before transmitting.
3.9.3 Firmware Updates
Before updating:
  • Charge the battery and keep the USB connection stable;
  • Back up channels and important settings;
  • Confirm that the release explicitly supports ThinkNode M9 V1.0 and its LR1110/display/keyboard pin map;
  • Read the release notes and verify a checksum if one is published;
  • Do not flash a generic build solely because it targets an ESP32-S3.
Use the firmware and flashing method published by Elecrow for the M9. The official Meshtastic web flasher is a reference tool, but the M9 must appear as a supported target or be accompanied by explicit M9 installation instructions before it is used.
3.10 Troubleshooting
3.10.1 No Nodes Are Found
  1. Confirm that both devices use the correct Region and compatible modem preset/frequency settings.
  2. Confirm that the antennas match the hardware band and are firmly attached.
  3. Place the devices nearby for the initial test and wait for periodic node-information packets.
  4. Confirm that neither device is in Bluetooth programming mode or shut down.
  5. Check Statistics and Packet Log for received traffic, RSSI, and SNR changes.
3.10.2 A Node Is Visible but Messages Are Not Exchanged
  • Verify the primary/secondary channel slot, name, and key on both devices.
  • Confirm compatible Region, modem preset, and frequency slot/override.
  • Try a short message to the primary channel at close range.
  • Do not treat an old node-list entry as proof that the node is currently online.
  • Review Packet Log and Trace Route, but avoid repeated diagnostics on a busy channel.
3.10.3 Bluetooth Pairing Fails
  1. Re-enter Bluetooth programming mode from Reboot / Shutdown.
  2. Use the new number displayed on the M9; old pairing numbers expire.
  3. Remove the old M9 record from the app and the phone's Bluetooth settings.
  4. Grant the Meshtastic app the Bluetooth/nearby-device permissions required by the phone OS.
  5. Restart Bluetooth or reboot both devices, then retry at close range.
3.10.4 Wi-Fi Is Enabled but Online Features Do Not Work
The Wi-Fi icon can indicate that Wi-Fi is enabled without proving Internet connectivity. Verify the SSID and password, 2.4 GHz availability, assigned IP address, router restrictions, and Internet access. MQTT must also have valid server, authentication, and channel-uplink/downlink settings.
3.10.5 GNSS Has No Fix
Move outdoors, enable GNSS, and keep the device stationary with a clear sky view. A cold start may require several minutes. Confirm that the position is current before sharing it. Lack of a GNSS fix does not prevent basic LoRa text communication.
3.10.6 The Map Is Blank
  • Confirm that the microSD card is detected and contains the expected map files;
  • Connect to a working Wi-Fi network if the firmware downloads map tiles automatically;
  • Check map coverage, zoom level, directory structure, and free storage space;
  • Remember that a missing GNSS fix affects centering on the current position but should not prevent browsing existing tiles.
3.10.7 The microSD Card Is Not Detected
Power down before reseating the card. Test a known-good card of a supported capacity and file system. Back up data before reformatting. If custom firmware is used, also confirm that SD_CS is GPIO48 and that the shared SPI chip-select signals are managed correctly.
For initial acceptance testing, complete these checks in order: attach the correct antenna → select the legal Region → configure two units with the same modem preset and channel → verify node discovery → exchange short group messages → exchange a direct message → obtain an outdoor GNSS fix → verify map positioning → enter Bluetooth programming mode and connect the Meshtastic app → back up the working configuration.
How to Buy
Visit the Elecrow official website and search for ThinkNode M9 Meshtastic. Confirm the hardware frequency band and included accessories before ordering.
Support
For product support, use the contact options on the Elecrow website or email techsupport@elecrow.com. For general Meshtastic concepts and app usage, consult the official Meshtastic documentation.
