Meshstick USB-To-SPI SX1262 TCXO LoRa USB Stick
Product Overview
Meshstick is an open-source LoRa Mesh USB adapter based on the CH341A and SX1262. It features a USB plug-in design, an integrated TCXO, and USB bus power, requiring no external power supply. The device can connect to Linux, macOS, or Windows computing devices and work with meshtasticd as a Meshtastic network node. It supports web-based management, message sending and receiving, and network monitoring, making it suitable for LoRa relay node and regional coverage gateway deployments.
Specifications
Parameter Specification
Product Model Meshstick USB-To-SPI SX1262 TCXO LoRa USB Stick
SKU LMM15202D
Brand Elecrow
Interface USB 2.0
Bridge Chip CH341A
LoRa Chip SX1262
Operating Frequency Band EU868 MHz / US915 MHz
Maximum Transmit Power +22 dBm
Antenna Connector SMA external antenna connector
Enclosure Translucent black plastic enclosure
Power Supply USB bus-powered, no external power supply required
Dimensions 88 x 30 x 18 mm, excluding antenna
Weight 36.6 g, including antenna
Package Contents 1 x Meshstick; 1 x antenna; 1 x quick start guide
Product Instructions
Resources
Support
