5.Port Introduction¶
Welcome to Lesson 5 of the CrowPanel ESP32 Advance HMI Series Tutorial, Port Introduction.
This lesson will use the IIC interface and UART1-OUT interface of this series of products to collect data from temperature and humidity sensors. When the temperature exceeds the threshold, the light bulb will automatically light up.
In this lesson, we will use the knowledge of LVGL graphics library from Lesson 3 to create an interactive interface.
1 Introduce product ports¶
This is the layout diagram of the 3.5-inch V1.0 model.
This is the layout diagram of the 3.5-inch V1.2 model.
2 Taking UART1-OUT interface and IIC-OUT as examples¶
Next, taking the external light bulb connected to the UART1-OUT interface and the temperature and humidity sensor connected to the IIC-OUT interface as an example. The temperature and humidity sensor needs to support IIC communication. The peripherals connected to the IIC interface are all like this.
In order to provide everyone with an intuitive observation, I will use LVGL to create an interactive interface.
Create Arduino project
Add the background image we provide based on the resolution required for the size you are using.
(choose different resolutions for different sizes, refer to the resolution size used for different sizes in Lesson 3)
Click the link below to download the supporting images for this lesson.
Resource link:
Click on Project Setting
Set the file export path and customize the path
But here, you need to create an Output folder in the path above to receive the exported UI files.
Fill in lvgl. h and select Flat export.
Finally confirm the settings
Go to the Output folder you just set up and copy the UI files you generated.
Paste it into the code file you need to open (here I will introduce the 3.5-size code as an example).
Then use Arduino IDE to open the ino file in the folder
3 Code Explanation¶
You can click the link below to download the corresponding version of the code for this lesson.
Code link:
3.5-inch V1.0:
3.5-inch V1.2 / V1.3:
Introduce several key points in the code
Initialize UART1-OUT pin, IIC pin, and temperature and humidity sensor
Turn on the screen backlight to enable the screen to display
Previously, pin 18 was set as the output mode, and the UART1-OUT interface was connected to the light bulb. By controlling pin 18, the light can be controlled.
The brightness and darkness of bubbles.
Because the temperature and humidity sensor is connected to the IIC interface, it is necessary to initialize pins 15 and 16 of the IIC and initialize the temperature and humidity sensor.
And define two variables to receive data collected by temperature and humidity sensors
And display the value on the label you previously designed
If the temperature value collected by your temperature and humidity sensor exceeds 30 ℃, the light bulb will automatically light up; If the temperature drops below 30 ℃, the light bulb will automatically turn off.
(You can modify the temperature threshold yourself, this is only for the convenience of observing the results)
Special Reminder:
(The following applies only to 2.8-inch and 2.4-inch products)
If you are using the 2.8-inch or 2.4-inch version of the product, you need to pay special attention to the issue of IIC device address conflicts. The IIC address of the onboard touch driver chip is 0x38, and the default IIC address of the DHT20 temperature and humidity sensor is also 0x38. When you connect the DHT20 temperature and humidity sensor to the IIC-OUT interface, since both devices use the same IIC address, an address conflict will occur, resulting in the devices being unable to communicate normally. In this situation, the system will give priority to ensuring the normal operation of the touch driver chip. Therefore, the touch function will not be affected, but the DHT20 temperature and humidity sensor will be unable to read data properly. To solve this problem, we suggest connecting the DHT20 temperature and humidity sensor to the UART1-OUT interface for use. This will prevent IIC address conflicts and ensure that the temperature and humidity sensor can operate normally. Additionally, it is important to note that the UART1-OUT interface actually provides two GPIO pins (IO17 and IO18) that are available for user use. You can use them as regular GPIOs and connect some peripherals that only require one or two IO pins.
For example, when connecting an LED light, IO18 can be used as the control pin, and the on/off state of the light can be controlled by the program.
It should be noted that the UART1-OUT interface only provides two GPIO pins, namely IO17 and IO18. Therefore, it is only suitable for peripheral devices that occupy a relatively small amount of IO resources. If certain modules require the use of more GPIO pins, such as SPI devices which typically need multiple signal lines including SCK, MOSI, MISO and CS, then they cannot be directly connected and used through the UART1-OUT interface.
2.4" 2.8"¶
And when initializing the temperature and humidity sensor, specify the IIC pin used for initializing the temperature and humidity sensor.
4 Hardware connection¶
UART1-OUT connection bulb
IIC-OUT connection to DHT20 temperature and humidity sensor
This is the hardware connection diagram for the 3.5-inch V1.0 version.
This is the hardware connection diagram for the 3.5-inch V1.2 version.
5 Configure the environment, upload code, and view phenomena¶
(Before uploading the code, please replace the relevant library files. Please refer to Lesson 1 for instructions on how to replace them.)
Configure the operating environment according to the guidance.
Upload code
Phenomenon display
Library file link:
