ESP32 Miner LCD-2.4 inch¶
Board Version
Lib Related Versions
Ivgl: 8.3.3
TFT_eSPI: 2.5.0
LovyanGFX: 1.1.8
Overview¶
Hardware Preparation¶
| CrowPanel ESP32 2.4'' HMI | Crowtail-DHT20 | Crowtail-LED |
Please click
to download the demo for "Example Demonstration" section in "Get Started with SquareLine Studio".
Note:
Set the name of the project, set the screen resolution to 320*240, set the color depth to 16bit, and keep other default settings. After setting, click CREATE to create the project.
Please click
Add background.
Find "Inspector"->"STYLE SETTING", click to expand "STYLE(MAIN)", then click the 2nd "Background"(in v1.3.4 is "Background image"). Check the "Bg Image" and select the background image.
Add events to buttons.
Export UI files.
Then click "APPLY CHANGES".
Please click
to download the main program(and the expert UI is included). -
Modify the button event code.
First, define a variable in the ui.c file to store the status of the LED. In the main program, the LED light is controlled to turn on and off by judging the status of this variable.
Build the Project with Arduino IDE¶
Get Started with Arduino IDE¶
Please refer to the Arduino IDE tutorial below and download the ESP32 version 2.0.14. The relevant code design of our product is accomplished based on the ESP32 version 2.0.14 to fulfill the code functions.
Install Libraries¶
#include <lvgl.h>
#include <TFT_eSPI.h>
#include <demos/lv_demos.h>
#include <Arduino.h>
#include <Crowbits_DHT20.h>
//UI
#include "ui.h"
#include <Arduino.h>: contains the Arduino core library, providing commonly used functions and data types. -
#include <lvgl.h>and#include <TFT_eSPI.h>: are libraries for graphical interfaces, used for display control and drawing. -
#include <demos/lv_demos.h>is a demo library provided by the LVGL official, which contains a variety of ready-made UI demonstration programs, such as component displays, animation effects, and interaction examples. It is not a necessary library for project operation. Currently, no example-related functions are called in the code, and deleting this import will not affect the normal function of the program. Its main purpose is in the development and debugging stage, where by calling example functions (such aslv_demos_widgets()), one can quickly verify whether the LVGL library is installed correctly and whether the display screen can show normally, helping developers quickly familiarize themselves with the functional features of LVGL. -
"ui.h": is a custom header file that contain UI-related functions or definitions.
- "Crowbits_DHT20.h": to read data from the DHT20 temperature and humidity sensor.
Please click
to download the libraries we modified.
Tips:
If you install the lvgl libraries by Library Manager, you need to copy the demos folder and examples folder and paste them to src folder. And modify the lv_conf_template.h file and rename it to lv_conf.h, and place it in libraries folder.(Please refer to the library provided)
If you install the TFT_eSPI libraries by Library Manager, you need to modify User_Setup.h file accordding to the hardware specification.(Please refer to the library provided)
Download version 8.3.3 of LVGL.
Code Explanation¶
Basic Definition
//Screen resolution definition, the resolution of 2.4 inches is 320*240
/*Changing the screen resolution*/
static const uint16_t screenWidth = 320;
static const uint16_t screenHeight = 240;
/*Define buffer variables to initialize the LVGL display driver and prepare a buffer to store pixel data that will be rendered to the screen. The size of this buffer is preferably about 1/10 of the product of screen pixel values, which can take into account both the main control performance and the smoothness of the screen display. Taking 8 as an example here, the display will be smoother.*/
static lv_color_t buf1[ screenWidth * screenHeight / 10 ];
// Initialize DHT20 sensor
Crowbits_DHT20 dht20;
TFT_eSPI lcd = TFT_eSPI(); /* TFT Example */
Function
/* Display Refresh */
/*The function of this code is to use the LCD object to perform the display refresh operation based on the given refresh area and color data, and notify the display driver to complete the refresh operation through the LVGL library. w * h indicates the number of color data, and true indicates that the color data written is 16 bits.*/
void my_disp_flush( lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p )
uint32_t w = ( area->x2 - area->x1 + 1 );
uint32_t h = ( area->y2 - area->y1 + 1 );
lcd.startWrite();
lcd.setAddrWindow( area->x1, area->y1, w, h );
lcd.pushColors( ( uint16_t * )&color_p->full, w * h, true );
lcd.endWrite();
lv_disp_flush_ready( disp );
/*Read Touchpad*/
/*The function of this code is to read the input status and coordinate information of the touch screen and store the results in the specified data structure. If the touch screen is touched, the coordinate information of the touch screen will also be printed to the serial monitor.
The number 600 represents the timeout in milliseconds, which is the maximum amount of time to wait while waiting for touch screen input.
When the lcd.getTouch function is called, it will try to read the input status and coordinate information of the touch screen. If the input is successfully read within 600 milliseconds, the function will return true, indicating that the touch screen was touched. If no input is read within 600 milliseconds, the function will return false, indicating that the touch screen was not touched.
This timeout can be adjusted as needed. A shorter timeout may prevent all coordinate points from being accurately captured when swiping quickly on the touch screen, while a longer timeout may increase response time. This timeout value can be adjusted appropriately according to specific application scenarios and requirements.*/
uint16_t touchX, touchY;
bool touched = lcd.getTouch( &touchX, &touchY, 600);
if ( !touched )
else
/*Setting the coordinates*/
data->point.x = touchX;
data->point.y = touchY;
Serial.print( "Data x " );
Serial.println( touchX );
Serial.print( "Data y " );
Serial.println( touchY );
Set Up Part
Serial.begin( 115200 ); /*Initializing the Serial Port*/
pinMode(4, INPUT);
//IO Port Pins
pinMode(25, OUTPUT);
digitalWrite(25, LOW);
Wire.begin(22, 21);
dht20.begin();
lcd.begin();
lcd.setRotation(1);
lcd.fillScreen(TFT_BLACK);
delay(100);
//Backlight Pins
pinMode(27, OUTPUT);
digitalWrite(27, HIGH);
SPI.begin(14, 4 , 13, 33);
lv_init();
lcd.setTouch( calData );
lv_disp_draw_buf_init( &draw_buf, buf1, NULL, screenWidth * screenHeight / 10 );
/*Initializing the display*/
lv_disp_drv_init( &disp_drv );
/*Change the following line to display resolution*/
lv_disp_drv_register( &disp_drv );
/*Initialize the (virtual) input device driver*/
lv_indev_drv_init( &indev_drv );
lv_indev_drv_register( &indev_drv );
ui_init();
Main Program Part
/*Obtain the temperature and humidity data and use a char array to store it. Use two integer variables a and b to store the obtained temperature and humidity*/
char DHT_buffer[6];
int a = (int)dht20.getTemperature();
int b = (int)dht20.getHumidity();
//Store the value in an array through conversion and display it on the label
/*judge the value of the LED. In the ui.c program, press the "ON" button to set the LED to 1 and control the LED light to turn on*/
if(led == 1)
digitalWrite(25, HIGH);
//*In the ui.c program, press the "OFF" button to set the LED to 0. At this time, the LED light is controlled to be turned off*/
if(led == 0)
delay( 10 );
The Complete Code
#include <lvgl.h>
//UI
#include "ui.h"
int led = 0;
uint16_t calData[5] = { 189, 3416, 359, 3439, 1 };
lcd.startWrite();
lcd.endWrite();
/*Read Touchpad*/
if ( !touched )
else
Serial.printf("Touch X:%d Y:%d\n", data->point.x, data->point.y);
pinMode(4, INPUT);
//IO Port Pins
Wire.begin(22, 21);
dht20.begin();
lcd.begin();
lcd.setRotation(1);
delay(100);
//Backlight Pins
lv_init();
ui_init();
Serial.println(led);
char DHT_buffer[6];
if(led == 1)
if(led == 0)
delay( 10 );
Upload the Code¶
After completing the installation of the ESP32 board according to "Get Started with Arduino IDE" and the installation of the library according to "Install Libraries", open the program and connect the ESP32 HMI 2.4-inch to the computer via a USB-C cable.
Select Board: click "Tools" -> "Board" -> "esp32" and select "ESP32-WROOM-DA Module"(select ESP32 Dev Module also be good)
Select Port
Upload the code
After the program is successfully uploaded, connect the DHT20 sensor to the IIC port and the LED to GPIO_D (IO25), the temperature and humidity values will be displayed on the screen. Click the ON button on the screen and the LED will turn on. Click the OFF button and the LED will turn off.
Example Demo of ESP32 HMI Function¶
Example1: LED blinking.¶
Connect the LED to GPIO_D(IO25) port, and upload the following code to the board. The LED will blinking.
#define D_PIN 25
Serial.begin(115200);
pinMode(D_PIN, OUTPUT);
digitalWrite(D_PIN, HIGH);
delay(500);
digitalWrite(D_PIN, LOW);
delay(500);
Example2: Control an external OLED screen through I2C.¶
Connect the OLED screen to IIC port.
Install the U8g2 library. Then upload the following code.
ESP32 version: 2.0.14
U8g2 version: 2.35.30
#include <U8g2lib.h>
#include <Wire.h>
#define I2C_SDA 22
#define I2C_SCL 21
U8G2_SSD1306_128X64_NONAME_F_SW_I2C u8g2(U8G2_R0, /*clock=*/I2C_SCL, /*data=*/I2C_SDA, /*reset=*/U8X8_PIN_NONE);
//OLED
u8g2.begin();
u8g2.enableUTF8Print(); // enable UTF8 support for the Arduino print() function
u8g2.setFont(u8g2_font_ncenB14_tr);
u8g2.setFontDirection(0);
for (int i = 128; i > -78; i -= 20)
u8g2.firstPage();
do {
u8g2.drawStr(i, 25, "ELECROW");
delay(2);
} while ( u8g2.nextPage() );
Example3: Play music¶
Plug the speaker into SPK port. Please check if you have installed the library XT_DAC_Audio(The download link is in the "Install Libraries" section of this tutorial) Upload the following code to the ESP display
#include "MusicDefinitions.h"
#include "SoundData.h"
#include "XT_DAC_Audio.h"
//SPEAK
// Data for the melody. Note followed by optional change in playing length in 1/4 beats. See documentation for more details
int8_t PROGMEM TwinkleTwinkle[] = {
NOTE_C5, NOTE_C5, NOTE_G5, NOTE_G5, NOTE_A5, NOTE_A5, NOTE_G5, BEAT_2,
NOTE_F5, NOTE_F5, NOTE_E5, NOTE_E5, NOTE_D5, NOTE_D5, NOTE_C5, BEAT_2,
NOTE_G5, NOTE_G5, NOTE_F5, NOTE_F5, NOTE_E5, NOTE_E5, NOTE_D5, BEAT_2,
NOTE_F5, NOTE_F5, NOTE_E5, NOTE_E5, NOTE_D5, NOTE_D5, NOTE_C5, BEAT_4,
NOTE_SILENCE, BEAT_5, SCORE_END
XT_DAC_Audio_Class DacAudio(26, 0); // Create the main player class object. Use GPIO 25, one of the 2 DAC pins and timer 0
XT_Wav_Class ForceWithYou(Force); // create WAV object and pass in the WAV data
XT_MusicScore_Class Music(TwinkleTwinkle, TEMPO_ALLEGRO, INSTRUMENT_PIANO); // The music score object, pass in the Music data
XT_Sequence_Class Sequence; // The sequence object, you add your sounds above to this object (see setup below)
Serial.begin( 9600 );
Sequence.AddPlayItem(&ForceWithYou); // Add the first sound item, this will play first
Sequence.AddPlayItem(&Music); // Add the music score, this will play after the first item
DacAudio.Play(&Sequence); // Play the sequence, will play just the once and then stop
DacAudio.FillBuffer();//Play
// DacAudio.StopAllSounds(); //Stop Playing
Example4: Initialize SD Card slot¶
Please check if you have installed the SD library(The download link is in the "Install Libraries" section of this tutorial) Upload the following code to the ESP display.
SDversion :2.0.0
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include <FS.h>
#define SD_MOSI 23
#define SD_MISO 19
#define SD_SCK 18
#define SD_CS 5
SPI.begin(SD_SCK, SD_MISO, SD_MOSI);
delay(100);
if (SD_init() == 1)
Serial.println("Card Mount Failed");
else
Serial.println("initialize SD Card successfully");
int SD_init()
if (!SD.begin(SD_CS))
return 1;
uint8_t cardType = SD.cardType();
if (cardType == CARD_NONE)
Serial.println("No TF card attached");
return 1;
uint64_t cardSize = SD.cardSize() / (1024 * 1024);
Serial.printf("TF Card Size: %lluMB\n", cardSize);
listDir(SD, "/", 2);
// listDir(SD, "/", 0);
// createDir(SD, "/mydir");
// removeDir(SD, "/mydir");
// listDir(SD, "/", 2);
// writeFile(SD, "/hello.txt", "Hello ");
// appendFile(SD, "/hello.txt", "World!\n");
// readFile(SD, "/hello.txt");
// Serial.printf("Total space: %lluMB\n", SD.totalBytes() / (1024 * 1024));
// Serial.printf("Used space: %lluMB\n", SD.usedBytes() / (1024 * 1024));
// Serial.println("SD init over.");
return 0;
//Traverse the directory of the SD card
void listDir(fs::FS & fs, const char *dirname, uint8_t levels)
// Serial.printf("Listing directory: %s\n", dirname);
File root = fs.open(dirname);
if (!root)
//Serial.println("Failed to open directory");
return;
if (!root.isDirectory())
Serial.println("Not a directory");
return;
File file = root.openNextFile();
// i = 0;
while (file)
if (file.isDirectory())
// Serial.print(" DIR : ");
// Serial.println(file.name());
if (levels)
listDir(fs, file.name(), levels - 1);
else
Serial.print("FILE: ");
Serial.print(file.name());
// lcd.setCursor(0, 2 * i);
// lcd.printf("FILE:%s", file.name());
Serial.print("SIZE: ");
Serial.println(file.size());
// lcd.setCursor(180, 2 * i);
// lcd.printf("SIZE:%d", file.size());
// i += 16;
Example5: Initialize the touch¶
Please check if you have install the library TFT_eSPI(The download link is in the "Install Libraries" section of this tutorial) Upload the following code to ESP display, and open the serial monitor to check the touch information.
TFT_eSPI version:2.5.0
Serial.begin( 115200 ); /*Initialize serial port*/
pinMode(4, INPUT);
//LCD Initialize
lcd.begin();
lcd.setRotation(1); /* Rotate */
//Calibration mode. One is four-corner positioning, and the other is direct positioning by directly inputting analog values.
//Screen calibration
// touch_calibrate();
lcd.setTouch(calData);
/*Initialization*/
if ( touched )
// Here, the X coordinate is flipped.
uint16_t fixedX = touchX;
uint16_t fixedY = touchY;
Serial.print("Data x ");
Serial.println(fixedX);
Serial.print("Data y ");
Serial.println(fixedY);
void touch_calibrate()
uint16_t calData[5];
uint8_t calDataOK = 0;
Serial.println("Touch-screen calibration");
//calibration
Serial.println("Please touch the corners as directed");
// lv_timer_handler();
lcd.calibrateTouch(calData, TFT_MAGENTA, TFT_BLACK, 15);
Serial.println("calibrateTouch(calData, TFT_MAGENTA, TFT_BLACK, 15)");
Serial.println(); Serial.println();
Serial.println("//Use this calibration code in setup():");
Serial.print("uint16_t calData[5] = ");
Serial.print("{ ");
for (uint8_t i = 0; i < 5; i++)
Serial.print(calData[i]);
if (i < 4) Serial.print(", ");
Serial.println(" };");
Serial.print(" tft.setTouch(calData);");
Example6: Initialize the interact communication of Bluetooth¶
Please check if you have installed the BLE library (the download link is in the "Install Library" section of this tutorial). Upload the following code to the ESP display and open the serial monitor to view the relevant information.
The display may not show up on an iPhone, but it does show up on an Android phone.
ESP32 BLE Arduino version:2.0.0
#include "BLEDevice.h" //BLE drive library
#include "BLEServer.h" //BLE server library
#include "BLEUtils.h" //BLE Utility library
#include "BLE2902.h" //Feature Add Descriptor Library
#include <BLECharacteristic.h> //BLE Feature function library
BLEAdvertising* pAdvertising = NULL;
BLEServer* pServer = NULL;
BLEService *pService = NULL;
BLECharacteristic* pCharacteristic = NULL;
#define bleServerName "ESP32SPI-BLE" //BLE Server name
#define SERVICE_UUID "6479571c-2e6d-4b34-abe9-c35116712345" //Server UUID
#define CHARACTERISTIC_UUID "826f072d-f87c-4ae6-a416-6ffdcaa02d73"
bool connected_state = false; //Create device connection identifier
class MyServerCallbacks: public BLEServerCallbacks //Create connection and disconnection calling classes
void onConnect(BLEServer *pServer)//Start connecting function
connected_state = true; //Device is connected correctly
void onDisconnect(BLEServer *pServer)//disconnect function
connected_state = false; //Device connection error
//BLE
BLEDevice::init(bleServerName); //Create BLE and set name
pServer = BLEDevice::createServer(); //Create BLE server
pServer->setCallbacks(new MyServerCallbacks()); //Set up connection and disconnection calling classes
pService = pServer->createService(SERVICE_UUID); //Create BLE service
pCharacteristic = pService->createCharacteristic( //Create ble feature(Characterristic_UUID)
CHARACTERISTIC_UUID,
BLECharacteristic::PROPERTY_READ | BLECharacteristic::PROPERTY_WRITE | BLECharacteristic::PROPERTY_NOTIFY);
pCharacteristic->setValue("ELECROW");
//start broadcast
pAdvertising = BLEDevice::getAdvertising(); //A bleadvertising class pointer padvertising is defined, which points to bledevice:: getadvertising()
pAdvertising->addServiceUUID(SERVICE_UUID);
pAdvertising->start(); //Start broadcasting
pService->start();
// pAdvertising->stop(); //Stop broadcasting
// pService->stop(); //Stop service
Example7: Initialize the WIFI¶
Please check if you have installed the bilrary WiFi(The download link is in the "Install Libraries" section of this tutorial) Upload the following code to ESP display
WiFi version:1.2.5
#include <WiFi.h>
const char *ssid = "elecrow888"; //Change to your SSID
const char *password = "elecrow2014"; //Change to your password
WiFi.begin(ssid, password);
WiFi.setAutoReconnect(true);//Set up automatic reconnection
delay(100);
Serial.println("connecting");
Serial.println("WiFi is connected.");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
// WiFi.disconnect();
Example8: Connect Crowtail-GPS module via UART to Get Location¶
EspSoftwareSerial version:8.1.0
//at 9600 bps 8-N-1
#include <SoftwareSerial.h>
SoftwareSerial SoftSerial(16, 17);
unsigned char buffer[256]; // buffer array for data recieve over serial port
int count=0; // counter for buffer array
SoftSerial.begin(9600); // the SoftSerial baud rate
Serial.begin(9600); // the Serial port of Arduino baud rate.
if (SoftSerial.available()) // if date is comming from softwareserial port ==> data is comming from SoftSerial shield
while(SoftSerial.available()) // reading data into char array
buffer[count++]=SoftSerial.read(); // writing data into array
if(count == 256)break;
Serial.write(buffer,count); // if no data transmission ends, write buffer to hardware serial port
clearBufferArray(); // call clearBufferArray function to clear the storaged data from the array
count = 0; // set counter of while loop to zero
if (Serial.available()) // if data is available on hardwareserial port ==> data is comming from PC or notebook
SoftSerial.write(Serial.read()); // write it to the SoftSerial shield
void clearBufferArray() // function to clear buffer array
for (int i=0; i<count;i++)
{ buffer[i]=NULL;} // clear all index of array with command NULL
