ESP IDF Installation Guide
ESP_IDF
ESP-IDF (Espressif IoT Development Framework) is the official software development framework for ESP32 series chips, providing comprehensive libraries, tools, and APIs for building embedded IoT applications.
Compile Environment Configuration:
Note: Before installing, make sure Git is already installed. If it isn't, click the link to install it.(https://git-scm.com/install/)
Installing ESP IDF in VS Code
(1) First, download Visual Studio Code from https://code.visualstudio.com/. Select the version compatible with your computer's operating system and download it.
P4-idf-1
(2)Double-click to install Visual Studio Code software, and simply proceed with the default installation throughout.
P4-idf-2
P4-idf-3
P4-idf-4
P4-idf-5
(3)Open Visual Studio Code, click on ‘Extensions’, search for Python, and install it.
P4-idf-6
(4)Search for ESP-IDF and install it.
The IDF version must be 5.4.2 or higher.
P4-idf-7
(5). Open the ESP-IDF Package Manager.
idf_new_1
(6). Click Start Installation.
idf_new_2
(7) Select “Custom Installation” to choose the version you want to install.
idf_new_3
(8) Select the chip you need here.
idf_new_4
(9) Select the version you want to install. Here, we’ll choose 5.4.2. You can select a higher version based on your needs.
idf_new_5
idf_new_6
(10) Select the image; the default setting is fine here.
idf_new_7
(11) Continue with the default tool selection idf_new_8Continue, idf_new_9
Select the installation path.
idf_new_10
(13) Click Start Installation.
idf_new_10
(14) Waiting for installation idf_new_11
Installation successful
idf_new_12
idf_new_13
