Product Wiki: 7" Home Assistant Control Panel (Elecrow CrowPanel ESP32-P4)¶
Table of Contents¶
- What This Product Is
- Key Features
- Hardware Specifications
- 7" vs 10.1" Comparison
- System Architecture and How It Works
- Box Contents and Prerequisites
- Ten-Minute Quick Start
- Part 1: Home Assistant Server Setup
- Part 2: Panel Setup
- Day-to-Day Use
- Firmware Updates
- Troubleshooting
- FAQ
- Security and Privacy Notes
- References
- Glossary
1. What This Product Is¶
This is a 7-inch, ready-to-use Home Assistant wall-mounted control panel, built on the Elecrow CrowPanel Advanced 7" ESP32-P4 HMI platform (Home Assistant edition SKU DHA02007C; the corresponding CrowPanel dev-board part number is DHE04107D).
It ships with Home Assistant firmware pre-installed. You do not write any ESP32 code and you do not build an LVGL interface. There are only three steps:
- Join Wi-Fi — connect the panel to your network.
- Fill in parameters — enter your Home Assistant server address and credentials on the panel.
- Install the add-on — install the companion add-on on your Home Assistant server.
Once that is done, the panel displays the very same dashboard you already use in Home Assistant — the same cards, scenes, switches and entities. Edit the dashboard in Home Assistant and the panel follows automatically; there is no second UI to maintain.
It is not a hub on its own. The panel cannot replace your Home Assistant server and has no automation engine of its own. It is an always-on wall-mounted thin client.
Note: like the 10.1" model, the 7" panel ships without a case (Without Case on the official product page). You will need to supply your own enclosure or wall frame.
Typical use cases¶
Always-on wall dashboards, bedside and entryway control screens, lighting and scene control, climate monitoring, energy dashboards, EV charging control, solar generation dashboards, security and sensor dashboards, home and building automation.
Compared with the 10.1" model, the 7" panel is smaller and lighter (450 g vs 960 g), which suits tight wall spaces, bedside tables or small utility-box mounting points.
Who it is for¶
Home Assistant users who want a dedicated touchscreen without writing ESP32 firmware or maintaining a separate HMI application.
2. Key Features¶
| Feature | Description |
| Home Assistant Ready | Pre-installed firmware; just join Wi-Fi and enter your server address |
| Ready Out of the Box | No ESP32 programming, no HMI development |
| 7" IPS Touchscreen | 1024 × 600, responsive capacitive touch |
| Wi-Fi Connected | Connects directly to your existing Home Assistant server |
| No Custom HMI Development | Reuses your existing dashboards, cards, scenes and controls |
| Powerful ESP32-P4 | Dual-core RISC-V processor for smooth HMI performance |
| Wi-Fi 6 + Bluetooth | 2.4 GHz Wi-Fi 6, Bluetooth 5.3 / BLE |
| Built-in Audio | Dual speakers and microphone, ready for interactive control and future voice features |
| Rich Expansion | GPIO, UART, I²C, USB-C, SD card, optional wireless modules |
| Compact Size | 180 × 105 mm, ~450 g — well suited to small spaces |
3. Hardware Specifications¶
3.1 SoC and Memory¶
| Item | Specification |
| Main chip | ESP32-P4 |
| CPU / SoC | ESP32-P4; HP system: RISC-V 32-bit dual-core up to 400 MHz; LP system: RISC-V 32-bit single-core up to 40 MHz |
| System memory | 768 KB L2MEM (HP), 32 KB SRAM (LP), 8 KB TCM, 32 MB PSRAM |
| Storage | 128 KB ROM (HP), 16 KB ROM (LP), 16 MB Flash |
| Development environment | ESP-IDF, Arduino IDE (not needed for normal use) |
| Firmware | Home Assistant firmware pre-installed (ready to use) |
3.2 Display¶
| Size | 7.0 inch |
| Resolution | 1024 × 600 |
| Panel type | IPS |
| Touch | Capacitive, single-touch / 5-point multi-touch |
| Viewing angle | 178° |
| Brightness | 400 cd/m² (typical) |
| Colour depth | 16.7M (8-bit) |
| Active display area | 155 mm × 87 mm |
Resolution matters. The server-side add-on always captures at 1024 × 600, so the panel must match or the image will be cropped or scaled.
Because the resolution is identical, the 7" panel has a higher pixel density (the same 1024 × 600 packed into a smaller screen). Up close the UI looks sharper, but the amount of information on screen is exactly the same as the 10.1" model — only the physical size is smaller.
3.3 Wireless (on-board antenna)¶
| Wi-Fi | 2.4 GHz (Wi-Fi 6), 802.11 b/g/n |
| Bluetooth | Bluetooth 5.3 + BLE |
| Optional | Zigbee, LoRa (SX1262), nRF2401, Matter, Thread, Wi-Fi HaLow (requires an add-on wireless module) |
3.4 Interfaces and Functions¶
| Interfaces | USB 2.0, UART, I²C, GPIO female headers, SD-card holder, battery socket, speaker jack, camera header, module female headers |
| Functions | Audio amplifier, battery charge management, USB-to-UART, microphones, dual speakers |
3.5 Buttons and Indicators¶
| Item | Description |
| Reset button | Present; press to reset the device |
| Boot button | Present; hold to put the board into programming mode |
| Power button | Switches the device on and off |
| PWR indicator | Device power on/off indication |
| CHG indicator | Lithium-battery charge status / low-battery indication |
3.6 Physical and Mounting¶
| Item | 7" (this product) |
| Board dimensions | 180 × 105 mm |
| Active display area | 155 × 87 mm |
| Weight | approx. 450 g |
| Power input | 5 V / 2 A (USB or UART terminal) |
| Operating temperature | -20 to 70 °C |
| Storage temperature | -30 to 80 °C |
| Mounting | Mounting holes on all four sides (M3, 3.2 mm); supports embedded mounting and enclosure assembly |
| Speaker connector | BX-PH 2.0-2PWT, 1×2P, 2 mm pitch, 8 × 8.5 × 5.6 mm, SMT right-angle |
| Enclosure | Not included |
Power warning: the official rating is 5 V / 2 A. Use a power supply that can genuinely deliver 2 A. Insufficient power shows up as repeated reboots, screen flicker or unstable Wi-Fi.
5. System Architecture and How It Works¶
Understanding this architecture explains most of the behaviour you will observe in practice.
The same architecture as plain text, for purely textual environments:
│ Home Assistant server │
│ (HA OS + Supervisor) │
│ │ Add-on: Elecrow ESP32P4│ │
│ │ Display (crow_ws_panel)│ │
│ │ · Xvfb virtual display│ │
│ │ · Headless Chromium │ │
│ │ opens the HA UI │ │
│ │ · Tile split + diff │ │
│ │ · JPEG on changed tiles│ │
│ │ · WebSocket server:3000│ │
│ Binary WebSocket (tiles downstream + touch upstream)
│ container port 3000
│ 7" ESP32-P4 panel │
│ · Paints incoming tiles │
│ · Sends touch/nav events │
│ · Runs no browser engine │
Key mechanics:
- Rendering does not happen on the panel. What you see is a frame stream produced by headless Chromium on the server. The panel paints tiles and reports touch; the browser, login and cookies all live server-side.
- Incremental transport. The add-on slices the frame into tiles and JPEG-compresses only the tiles that changed, so bandwidth is far lower than full-frame streaming.
- Fixed parameters (current version): capture resolution
1024 × 600, frame rate15 fps, start URLhttp://homeassistant:8123. The start URL uses the Supervisor's internal hostname, so it does not depend on your external or LAN address. - Single client. One add-on instance serves one panel. A new connection drops the previous panel and restarts the capturer (documented as a limitation of the current version).
- Session persistence. After the first successful login, the Home Assistant frontend session (
hassTokens) is stored per panelidat/data/tokens/<id>.jsonand reused on later connections, skipping the login screen. - Credentials travel in plaintext in the WebSocket query string. Officially documented as a current-version limitation, which is why the panel and Home Assistant must sit on a trusted network.
Ports at a glance:
| Port | Where | Purpose |
| 3000 | Add-on container (can be mapped to a host port) | WebSocket channel for frame stream + touch input; this is what the panel's WS Port points at |
| 8123 | Home Assistant | HA web UI, opened by the add-on's internal browser |
6. Box Contents and Prerequisites¶
Prerequisites (per the official guide)¶
- A running Home Assistant server;
- A usable Wi-Fi network (2.4 GHz);
- Home Assistant credentials (username and password);
- A data-capable USB cable (not a charge-only cable).
What to prepare¶
- The 7" ESP32-P4 panel (no case included);
- A USB cable and a 5 V / 2 A power supply (do not use an underpowered charger);
- M3 screws if you intend to wall-mount (four 3.2 mm mounting holes);
- Your Home Assistant server address (e.g.
LAN IP http://192.168.x.x).
7. Ten-Minute Quick Start¶
- Server side: Home Assistant →
Settings→Add-ons→ three-dot menu ⋮ →Repositories→ addhttps://github.com/fintros/crow-ha. - Server side: find and install the Elecrow ESP32P4 Display add-on, enable
Start on bootandWatchdog, clickStart, wait for the status to become Running. - Panel side: power the panel over USB (5 V / 2 A) and wait for it to boot (first boot can take 1–2 minutes).
- Panel side: tap the gear icon and go to
Settings→Wi-Fi, pick your network and enter the password. - Panel side: if a firmware update is offered, tap
Update(never cut power during the update). - Panel side: go to
Settings→Home Assistant, enter the server address and credentials, and setWS Portto 3000. - Panel side: return to the Home Assistant screen — the panel connects and opens your dashboard.
8. Part 1: Home Assistant Server Setup¶
Step 1: Open Home Assistant in a browser¶
Browse to your Home Assistant instance (e.g. http://homeassistant.local:8123) and sign in with an administrator account.
Step 2: Open the add-on store¶
Settings → Add-ons → Install app.
Step 3: Open the repositories manager¶
Click the three-dot menu ⋮ in the upper-right corner and choose Repositories.
Step 4: Add the third-party repository¶
Click Add and enter the repository URL:
Confirm.
Step 5: Return to the add-on store¶
Click the back arrow to leave the repositories screen.
Step 6: Find the add-on¶
Type Elecrow in the search field and locate Elecrow ESP32P4 Display.
Step 7: Install the add-on¶
Open Elecrow ESP32P4 Display and click Install, then wait for it to finish.
The add-on pulls the prebuilt image
grovety/crow-ws-server, so nothing is compiled locally and installation is usually quick.
Step 8: Enable the important options¶
On the installed add-on page, enable:
- Start on boot — recommended;
- Watchdog — recommended.
Step 9: Start it and confirm it is running¶
Click Start and wait until the status shows Running.
Checklist:
- The add-on status shows Running;
Start on bootandWatchdogare both on; - The add-on
Logshows the WebSocket server listening on port 3000 (a connection entry appears once the panel connects).
Optional port change: the add-on's WebSocket server always listens on container port
3000. To expose a different host port, open the add-on'sNetworkpanel, map3000/tcpto the host port you want, restart the add-on, and enter that new port as the panel'sWS Port.
9. Part 2: Panel Setup¶
Step 1: Power on¶
Connect the panel over USB (5 V / 2 A) and wait for it to boot.
The first boot may take 1–2 minutes. Be patient and do not cycle the power.
While booting, the screen shows Waiting for WiFi... with a Wi-Fi icon and a gear icon in the upper-right corner.
Step 2: Open Settings¶
Tap the gear icon in the upper-right corner to open Settings.
Step 3: Choose a Wi-Fi network¶
Open the Wi-Fi tab and select your network from the Available Networks list (signal strength is shown, e.g. -64 dBm).
Step 4: Enter the password and save¶
Type the Wi-Fi password in the dialog and tap Confirm. A Show button reveals the password temporarily in plain text.
Confirm the connection: a Connected status must appear next to the network name.
If your network is not listed: leave the Wi-Fi screen and open it again — the panel rescans.
Do not continue until the network shows as connected.
Step 5: Install a firmware update if offered¶
If a Firmware update available dialog appears (showing current and target versions):
- Expand
Release notesto read what changed; - Tap
Update; - Never cut power or disconnect the panel during the update and reboot.
Strongly recommended: update to the latest firmware before configuring Home Assistant. Older builds may have connectivity or TLS-related issues (for example the
1.1.1: TLS replace requestfix).
Step 6: Open the Home Assistant settings page¶
On the panel, go to Settings → Home Assistant.
The page contains four blocks:
| Block | Description |
| Server URL | Home Assistant server address |
| Account | Login username and password |
| WS Port | WebSocket port, default 3000 |
| Setup via QR | Configure from a phone by scanning a QR code (shows Connected to <your Wi-Fi> and Setup Page <IP>) |
Status badges on the right: CONFIGURED = set, DEFAULT = using the default value.
Step 7: Enter the server address¶
In Server URL, enter your Home Assistant address, for example:
Step 8: Enter the Home Assistant account¶
Fill in the Home Assistant username and password under Account.
Official recommendation: create a dedicated Home Assistant user for the panel (e.g.
panel). This lets you: - scope which entities and dashboards the panel can reach; - revoke or rotate panel credentials at any time without touching your main account.
Step 9: Enter the WS Port¶
Set WS Port to:
(If you changed the add-on's host port mapping in Part 1, enter the new port instead.)
Step 10: Return and connect¶
Go back to the Home Assistant screen. The panel connects to the server automatically and opens your Home Assistant dashboard.
Checklist:
Server URL,AccountandWS Portall showCONFIGURED(orDEFAULT); - The panel loads your Home Assistant dashboard;
- Touch input responds — you can switch tabs and scroll;
- The server-side add-on log records the panel connection.
Alternative: configure by QR code. The
Home Assistantpage offersSetup via QR. Scan the code with a phone to open the panel's configuration page (the address shown asSetup Page, e.g.192.168.0.102) and fill in the Home Assistant connection details there. TheWi-Fipage similarly offers aSetup via mobileQR flow (1. Connect to ESP32-P4-Config/2. Open setup 192.168.4.1) for password entry without using the on-screen keyboard.
10. Day-to-Day Use¶
On-screen entry points¶
The main screen is your Home Assistant dashboard. Two icons are always available in the upper-right corner:
- Wi-Fi icon — network status;
- Gear icon — opens
Settings.
Settings page layout¶
Three vertical tabs on the left:
| Tab | Contents |
| System | System settings, including checking for and applying firmware updates |
| Wi-Fi | Network selection, password, connection status, QR-based setup from a phone |
| Home Assistant | Server URL, account, WS port, QR setup, HA OS Application entry |
The ← button in the lower-left leaves Settings.
Changing the dashboard¶
There is nothing to do on the panel. Edit dashboards, add or remove cards, or change entities in Home Assistant — the panel follows automatically, because the frame is rendered and pushed server-side.
Fitting the UI to a 7" screen¶
Because the 7" and 10.1" panels share the same resolution (1024 × 600), they show exactly the same amount of information; the 7" is simply smaller and denser. If text feels small on the 7":
- create a dedicated view for the panel in Home Assistant with fewer, larger cards;
- use a kiosk-style theme or cards that reduce the grid column count (e.g. 4 → 3 columns);
- note that the panel itself cannot change scaling — the capture resolution is fixed at 1024 × 600 by the server add-on.
11. Firmware Updates¶
From
CrowPanel_Quick_Update_Guide_v3.pdf: whenever the panel misbehaves, check for a firmware update first.
The panel must be connected to Wi-Fi before checking.
| Step | Action |
| Step 1 | On the main screen, tap the Settings icon |
| Step 2 | In Settings choose System, then tap Check in the Firmware update section |
| Step 3 | If an update is available, a confirmation dialog appears — tap Update |
| Step 4 | Wait for the firmware to download and install. Do not power off or disconnect the panel, it reboots automatically when done |
| Step 5 | After the reboot, open Settings → System again and confirm the version shown under Firmware update matches the new version |
Notes:
- Wi-Fi is required; without it the update check cannot run;
- cutting power mid-update can leave the device in a bad state — keep the 5 V / 2 A supply stable;
- the panel's own dialog shows both
Current versionandNew version, withRelease notes; - keep the server-side add-on up to date as well (there is an
Auto updatetoggle on the add-on page).
12. Troubleshooting¶
Server side (add-on)¶
| Symptom | Likely cause and fix |
| Panel is blank / connection refused | Confirm the add-on is Started and that you are connecting to the host port mapped in its Network panel |
| Stuck on the login screen | Check the username and password entered on the panel; look for [JS] Login failed in the add-on log |
| Image cropped or scaled | Capture is fixed at 1024 × 600 (the 7" panel is also 1024 × 600, so this should not happen). If it does, check the panel firmware is current |
| Need a clean login | Log out in the Home Assistant UI, or stop the add-on and delete /data/tokens/<id>.json |
| Wrong dashboard / HA unreachable | The start URL is fixed at http://homeassistant:8123 and is not configurable in this version. If your HA is not reachable there, adjust your HA setup or wait for upstream support |
| Add-on not visible after adding the repository | Close and reopen the repository dialog and wait for Home Assistant to refresh the add-on list |
Panel side¶
| First boot seems to hang | 1–2 minutes on first boot is normal — wait it out |
| Repeated reboots / screen flicker | Usually insufficient power: the 7" is rated 5 V / 2 A. Use a supply that delivers it and a good-quality data cable |
| Your network is missing from the Wi-Fi list | Leave the Wi-Fi screen and reopen it to rescan; make sure you are using the 2.4 GHz band |
| Stuck on "Not connected" | Re-check the password; confirm the router is not using AP isolation or MAC filtering |
| Cannot reach the server | Ensure Server URL includes http:// and :8123; try the LAN IP instead of homeassistant.local |
| Screen does not refresh / freezes | Check for a firmware update first, then confirm the add-on is still running, then check network stability |
| Panel misbehaves in general | Check for a firmware update first (see section 11) |
General triage order¶
- Is the panel actually on Wi-Fi? (Settings → Wi-Fi, look for Connected)
- Is the panel firmware current? (Settings → System → Check)
- Is the server add-on Running? (HA → Add-ons → Elecrow ESP32P4 Display)
- Is
WS Port3000 (or whichever host port you mapped)? - Have you tried the LAN IP instead of
*.local? - Are the HA credentials correct, and is the account enabled?
- (7"-specific) Is the supply a full 5 V / 2 A? Underpowering masquerades as a network or firmware fault.
13. FAQ¶
Q1. Do I have to write code or build an interface? No. The firmware is pre-installed and the UI is your existing Home Assistant dashboard — no ESP32 programming and no LVGL development.
Q2. Can the panel work on its own? No. It is not a standalone smart-home hub; it requires a running Home Assistant server.
Q3. Is rendering local or remote? Remote. The server add-on renders the Home Assistant page in headless Chromium, compresses changed tiles and streams them over WebSocket. The panel paints tiles and sends touch events back.
Q4. Why must WS Port be 3000? The add-on's WebSocket server always listens on container port 3000; the panel receives frames and returns touch over it. You only change it if you remapped the add-on's host port.
Q5. Should Server URL be homeassistant.local:8123 or an IP? Both work, but a LAN IP is more reliable (e.g. http://192.168.0.109). mDNS resolution can be flaky on some routers.
Q6. Can I log in with my main account? You can, but it is recommended to create a dedicated Home Assistant user for the panel, for permission scoping and easy credential rotation.
Q7. Can I connect several panels? The current add-on is single-client — one panel per instance. Multiple panels require multiple instances. This also applies when mixing a 7" and a 10.1" panel.
Q8. Can I cut power during a firmware update? No. Interrupting an update or the following reboot can leave the device unbootable. Make sure Wi-Fi is connected first.
Q9. Does it ship with a case? No. The official product page lists the 7" panel as Without Case.
Q10. What is the resolution? 1024 × 600, IPS, capacitive touch, 178° viewing angle, 400 cd/m² — identical to the 10.1" model.
Q11. Does it support voice? The hardware includes dual speakers and a microphone; the official description says it supports interactive control and is ready for future voice features. Touch is the primary interaction today.
Q12. Does any data go through the cloud? No. Rendering happens on your local Home Assistant server, and panel-to-server traffic is a direct LAN WebSocket connection.
Q13. Is the firmware shared between the 7" and 10.1" models? They share the same Home Assistant firmware and server add-on, so the software stack is consistent. Because the screen sizes differ, update through the panel's own Settings → System → Check rather than flashing another size's image manually.
Q14. Can a 7" and a 10.1" panel share one add-on instance? No. The add-on is single-client. Run two instances for two panels, and make sure their host port mappings do not collide.
Q15. Does the 7" show less than the 10.1"? No. Both are 1024 × 600, so the information capacity is the same; only the physical size differs. If text feels small, enlarge cards on the Home Assistant side — you cannot change resolution on the panel.
14. Security and Privacy Notes¶
Officially documented limitations of the current version (the same on the 7" and 10.1"):
- Credentials are sent in plaintext. The panel sends the Home Assistant username and password in the WebSocket query string, unencrypted. Therefore:
- keep the panel and the Home Assistant server on a trusted LAN; never expose them to the internet;
- create a permission-scoped Home Assistant user for the panel.
- A long-lived session is stored server-side. The add-on saves the Home Assistant frontend session (including a non-expiring
refresh_tokenwith full account access) in plaintext at/data/tokens/<id>.json. Protect the Home Assistant host. - To force a fresh login: stop the add-on → delete that panel's
/data/tokens/<id>.json→ restart the add-on. - The add-on has no display of its own. It only serves the physical panel; its output is visible only there.
15. References¶
Online resources¶
- Product page (official, 7" HA edition): 7inch Home Assistant Smart Control Panel, ESP32-P4, 1024x600 IPS, Ready-to-Use (SKU
DHA02007C) - Hardware platform page (official, 7" dev board): CrowPanel Advance 7inch ESP32-P4 HMI AI Display 1024x600 IPS Touch Screen (SKU
DHE04107D-1) - 10.1" product page (for comparison): 10.1inch Smart Home Control Panel for Home Assistant (SKU
DHE01101C) - Home Assistant add-on repository: fintros/crow-ha (add-on name Elecrow ESP32P4 Display, slug
crow_ws_panel) - ESPHome build-it-yourself alternative (advanced, optional): fintros/ESPHome-CrowPanel-ESP32-P4 — the author states it is validated on the 10" panel and should also work on smaller displays
- Technical support: techsupport@elecrow.com (designated in the official guide for installation and panel-connection issues)
16. Glossary¶
| Term | Meaning |
| Home Assistant (HA) | Open-source, local-first smart-home platform; the server software this product depends on |
| Add-on | A containerised extension running on Home Assistant OS. This product needs the Elecrow ESP32P4 Display add-on |
| Supervisor | The Home Assistant OS component that manages add-ons and the system |
| Server URL | The Home Assistant address the panel connects to, e.g. http://homeassistant.local:8123 |
| WS Port | The WebSocket port carrying the frame stream and touch channel; defaults to 3000 |
| WS / WebSocket | Full-duplex network protocol used to carry tiles and touch events |
| Tile | A rectangular slice of the frame; the add-on compresses and sends only the tiles that changed |
| ESP32-P4 | Espressif's dual-core RISC-V high-performance MCU; the main SoC of this product |
| PSRAM | Pseudo-static RAM, 32 MB, used for graphics buffering |
| IPS | Wide-viewing-angle LCD technology; 178° here |
mDNS / .local | LAN hostname resolution used for homeassistant.local; unreliable on some networks |
hassTokens | The Home Assistant frontend session token; persisted by the add-on |
| Thin client | This product's model: local device only displays and captures input; rendering happens server-side |
| Firmware | The ESP32 program inside the panel; updatable online via Settings → System |
| Active area | The region of the screen that actually displays an image; 155 × 87 mm on the 7", smaller than the 180 × 105 mm board |
