ESP32_Miner_LCD-2.8_inch_PlatformIO
Overview
This example tutorial is a project for controlling the on and off of an LED. It demonstrates how to create a UI and how to control the on and off of an LED through buttons on the screen.
In this tutorial, we will show you how to design the UI with SquareLine Studio, and show you how to build a project on PlatformIO.
ESP32-led
Hardware Preparation
CrowPanel ESP32 2.8'' HMI Crowtail-DHT20 Crowtail-LED
CrowPanel-ESP32-2-8inch CROWTAIL-DHT20 CROWTAIL-LED
BUYNOW BUYNOW BUYNOW
GetStartedWithSquareLine
  1. Open the SquareLine Studio and create a project. Select "Arduino"->"Arduino with TFT_eSPI".
    SLS-UI-1
    Note:
    When select the Arduino framwork, there's only one option "Arduino with TFT_eSPI". By choosing this, the squareline studio will generate a template code suitable for the TFT_eSPI library. However, squareline studio not only supports the TFT_eSPI library, it supports a variety of libraries to suit different hardware and application needs. For example, Adafruit_GFX library, LovyanGFX etc.
  2. Set the name of the project, set the screen resolution to 320*240, set the color depth to 16bit, and keep other default settings. After setting, click CREATE to create the project.
    SLS-UI-2
  3. After creation, enter the following interface with a blank background.
    SLS-UI-3
  4. In the "Assets" area, click "ADD FILE TO ASSETS" to add custom images or icons.
    SLS-UI-4
    Note:
    Images only support webp format. The pixels of the image need to be smaller than the pixel size of the screen used in your project. The size of each image should not exceed 100k, preferably within 30k, to provide a smooth display effect.
  5. Add background.
    SLS-UI-5
    SLS-UI-6
  6. Add Label widget to display temperature and humidity.
    SLS-UI-7
    SLS-UI-8
    SLS-UI-9
    SLS-UI-10
    SLS-UI-11
    SLS-UI-18
  7. Add Button widget to control the LED.
    SLS-UI-12
    SLS-UI-13
    SLS-UI-14
    SLS-UI-15
    SLS-UI-16
    SLS-UI-17
    SLS-UI-19
    SLS-UI-20
  8. Add events to buttons.
    SLS-UI-21
    SLS-UI-22
    SLS-UI-23
    SLS-UI-24
  9. Export UI files.
    SLS-UI-25
    SLS-UI-26
    Then click "APPLY CHANGES".
    SLS-UI-27
    SLS-UI-28
    SLS-UI-29
  10. Modify the button event code.
    First, define a ‘extern int led;' in the ui.h file to store the status of the LED. The value of this variable is judged to control the on and off of the LED.
    SLS-UI-30
    SLS-UI-31
    • When button 1 (ON button) is pressed, set the LED value to 1.
      SLS-UI-32
    • When button 2 (OFF button) is pressed, set the LED value to 0.
      SLS-UI-33
    The UI file export is completed, and the button event function is also modified. Next we're going to learn about how to create a PlatformIO project.
Create PlatformIO Project
Please click download to download complete PlatformIO project that can be compiled and run directly.
Now let's explore how to build this project step by step!
Get Started with PlatformIO
Please click the card below to enter the page to get started with PlatformIO.
GetStartedWithPlatformIO
Create a new project
  1. Open Visual Studio Code, click the PlatformIO icon, click QUICK ACCESS 'Open', then click '+New Project'.
    PIO-2
  2. Add a project name "CrowPanel_ESP32_2.8". Select "Denky(WROOM32)" for the board and "Arduino" for the framework.
    PIO-3
  3. Write the main program in main.cpp.
    PIO-5
      #include <lvgl.h>
      #include <TFT_eSPI.h>
      #include <demos/lv_demos.h>
      #include <Arduino.h>
      #include <DHT20.h>
      //UI
      #include "ui.h"
      int led = 0;
      /*Changing the screen resolution*/
      static const uint16_t screenWidth  = 320;
      static const uint16_t screenHeight = 240;
      static lv_color_t buf1[ screenWidth * screenHeight / 10 ];
      TFT_eSPI lcd = TFT_eSPI(); /* TFT Example */
      // Initialize DHT20 sensor
      DHT20 dht20;
      uint16_t calData[5] = { 189, 3416, 359, 3439, 1 };
      /* Display Refresh */
      void my_disp_flush( lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p )
          uint32_t w = ( area->x2 - area->x1 + 1 );
          uint32_t h = ( area->y2 - area->y1 + 1 );
          lcd.startWrite();
          lcd.setAddrWindow( area->x1, area->y1, w, h );
          lcd.pushColors( ( uint16_t * )&color_p->full, w * h, true );
          lcd.endWrite();
          lv_disp_flush_ready( disp );
      uint16_t touchX, touchY;
      /*Read Touchpad*/
          bool touched = lcd.getTouch( &touchX, &touchY, 600);
          if ( !touched )
          else
              /*Setting the coordinates*/
              data->point.x = screenWidth - touchX; // 2.4 Usage of Size This line of code
              // data->point.x = touchX;               // 2.8 Usage of Size This line of code
              data->point.y = touchY;
              Serial.printf("Touch X:%d  Y:%d\n", data->point.x, data->point.y);
          Serial.begin( 115200 ); /*Initializing the Serial Port*/
          pinMode(4, INPUT);
          //IO Port Pins
          pinMode(25, OUTPUT);
          digitalWrite(25, LOW);
          Wire.begin(22, 21);
          dht20.begin();
          lcd.begin();
          lcd.setRotation(1);
          lcd.fillScreen(TFT_BLACK);
          delay(100);
          //Backlight Pins
          pinMode(27, OUTPUT);
          digitalWrite(27, HIGH);
          SPI.begin(14, 4 , 13, 33);
          lv_init();
          lcd.setTouch( calData );
          lv_disp_draw_buf_init( &draw_buf, buf1, NULL, screenWidth * screenHeight / 10 );
          /*Initializing the display*/
          lv_disp_drv_init( &disp_drv );
          /*Change the following line to display resolution*/
          lv_disp_drv_register( &disp_drv );
          /*Initialize the (virtual) input device driver*/
          lv_indev_drv_init( &indev_drv );
          lv_indev_drv_register( &indev_drv );
          ui_init();
          Serial.println(led);
          char DHT_buffer[6];
          int a = (int)dht20.getTemperature();
          int b = (int)dht20.getHumidity();
          if(led == 1)
              digitalWrite(25, HIGH);
          if(led == 0)
          delay( 10 );
Add Libraries
  1. Click the PlatformIO icon, click QUIK ACCESS 'Open', then click 'Libraries'.
    PIO-6
  2. Search for LVGL, and add it to the project.
    PIO-7
    PIO-8
    PIO-9
    PIO-10
    After adding, right click on lvgl and select "Open in Integrated Terminal"
    PIO-17
    Copy the "demos" and "examples" folders to "src" folder
    PIO-18
    Place the lv_conf.h we provide to the path: .pio\libdeps\denky32 in the project folder.
    PIO-19
    Please click download to download the lv_conf.h file.
  3. Add TFT_eSPI library.
    PIO-11
    PIO-12
    PIO-13
    PIO-14
    We can see that the library has been added successfully!
    Delete the User_Setup.h in the TFT_eSPI folder and copy the provided User_Setup.h to the TFT_eSPI folder.
    Please click download to download the User_Setup.h file.
  4. Add DHT20 library.
    Right-click the "libdeps\denky32", click "Reveal in File Explorer", and select the DHT20 library we provided.
    Please click download to download the DHT20 library.
Add the UI file into PlatformIO Project
We need to add the UI file (generated from SquareLine Studio) to the PlatformIO project.
The .c files in the UI file should be placed in the /scr folder of the project file, and the .h files should be placed in the /include folder.
PIO-34
PIO-35
Upload the Code
  1. Compile the program.
    Upload-code-1
  2. Select the serial port and upload the code.
    Here we select Auto. The software will automatically select the corresponding serial port for program download. If the automatically selected serial port is incorrect, you can manually select the correct serial port.
    Upload-code-2
  3. Click the upload button to up the program to the board.
    Upload-code-3
  4. The program will run on the board!
    ESP32-led
Resources
