CrowPanel Advance 2.4inch ESP IDF Course V12
# CrowPanel Advance 2.4-inch HMI ESP32-S3 Screen ### ESP-IDF Course Guide **320 x 240 IPS Touchscreen | ESP32-S3 | ESP-IDF | V1.2** ---
Product Model: CrowPanel-Advance-2.4-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen
Hardware Version: V1.2
Number of Lessons: 5 lessons
Development Platform: ESP-IDF v5.5.4 + ESP32-S3
Learning Path: ESP-IDF Environment Setup -> Network Audio -> LVGL Light Control -> DHT20 Temperature and Humidity Display -> SD Card Image Display
1. Course Overview
This course is designed for the CrowPanel Advance 2.4-inch HMI ESP32-S3 Screen V1.2 and uses native ESP-IDF projects for development. The course starts with ESP-IDF development environment installation and serial port verification, then walks through network audio playback, LCD / Touch / LVGL 9.1.0 graphical interface control, DHT20 temperature and humidity data acquisition and display, and SD card image reading and screen display.
The 2.4-inch and 2.8-inch screens both have a resolution of 320 x 240. This guide focuses on the 2.4inch V1.2 version.
2. Preparation Before Getting Started
  • Hardware: CrowPanel Advance 2.4-inch HMI ESP32-S3 Screen
  • USB Cable: Use a USB cable that supports data transfer
  • Development Software: Visual Studio Code + ESP-IDF Extension
  • ESP-IDF Version: v5.5.4
  • Getting Started with ESP IDF:https://www.elecrow.com/wiki/ESP_IDF_Installation_Guide.html
  • Target Chip: esp32s3
  • Screen Resolution: 320 x 240
  • Graphics Library: LVGL 9.1.0
  • Base Environment: First complete the ESP-IDF installation, target chip setup, serial port setup, build, and flashing verification in Lesson 1
3. Course Code
Main ESP-IDF Code Link: https://github.com/Elecrow-RD/CrowPanel-Advance-2.4-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-320x240/tree/master/example/V1.1_and_V1.2/ESP_IDF
4. Course Directory
Lesson Lesson Name Main Content
01 Install Software Environment Install the ESP-IDF environment, configure the target chip, and complete serial port verification
02 Network Audio Playback Implement network audio playback using ESP-IDF
03 LVGL Light Control Initialize LCD, Touch, and LVGL 9.1.0, and control GPIO18 through an on-screen button
04 DHT20 Temperature and Humidity Display Read DHT20 temperature and humidity data and display it on the LVGL interface
05 SD Card Image Display Read image files from an SD card and display them on the screen
Lesson 01 | ESP-IDF Environment Installation and Serial Port Verification
Lesson Link: https://www.elecrow.com/wiki/IDF_01_Install_Software_Environment_V13.html
Lesson 02 | Network Audio Playback
Lesson Link: https://www.elecrow.com/wiki/2.4_2.8_ESP-IDF-02-Network_Audio_Playback.html
Lesson 03 | LVGL Light Control
Lesson Link: https://www.elecrow.com/wiki/2.4_2.8_ESP-IDF-03-LVGL_Light_Control.html
Lesson 04 | DHT20 Temperature and Humidity Display
Lesson Link: https://www.elecrow.com/wiki/2.4_2.8_ESP-IDF-04-DHT20_Temperature_and_Humidity_Display.html
Lesson 05 | SD Card Image Display
Lesson Link: https://www.elecrow.com/wiki/2.4_2.8_ESP-IDF-05-SD_Card_Image_Display.html
Study in order from Lesson 01 to Lesson 05:
  1. Development Basics: In Lesson 01, first complete ESP-IDF v5.5.4 environment installation, target chip esp32s3 configuration, serial port connection, build, and flashing verification.
  2. Audio Function: In Lesson 02, learn the network audio playback workflow and understand the audio playback task and peripheral initialization in an ESP-IDF project.
  3. Display and Touch: In Lesson 03, learn how to use LCD, Touch, LVGL 9.1.0, and GPIO control together.
  4. Sensor Display: In Lesson 04, learn how to read the DHT20 temperature and humidity sensor and update the data on the LVGL interface.
  5. Storage and Image Display: In Lesson 05, learn SD card file reading and image display to build a foundation for future graphical interface projects.
**First complete ESP-IDF environment verification, then progressively learn audio, LVGL, sensors, and SD card display to build an ESP-IDF development foundation for the 2.4inch HMI screen.**
