CrowPanel Advance 2.8inch ESP IDF Course V12
Product Model: CrowPanel-Advance-2.8-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen
Hardware Version: V1.2
Number of Lessons: 5 lessons
Development Platform: ESP-IDF v5.5.4 + ESP32-S3
Learning Path: ESP-IDF Environment Setup -> Network Audio -> LVGL Light Control -> DHT20 Temperature and Humidity Display -> SD Card Image Display
1. Course Overview¶
This course is designed for the CrowPanel Advance 2.8-inch HMI ESP32-S3 Screen V1.2 and uses native ESP-IDF projects for development. The course starts with ESP-IDF development environment installation and serial port verification, then proceeds through network audio playback, LCD / Touch / LVGL 9.1.0 graphical interface control, DHT20 temperature and humidity data acquisition and display, and SD card image reading and screen display.
The 2.4-inch and 2.8-inch screens both have a resolution of 320 x 240, and they share the same ESP-IDF course content and lesson links. This guide focuses on the 2.8inch V1.2 version.
2. Preparation Before Starting¶
- Hardware: CrowPanel Advance 2.8-inch HMI ESP32-S3 Screen V1.2
- USB Cable: Use a USB cable that supports data transfer
- Development Software: Visual Studio Code + ESP-IDF Extension
- ESP-IDF Version: v5.5.4
- Getting Started with ESP IDF: https://www.elecrow.com/wiki/ESP_IDF_Installation_Guide.html
- Target Chip: esp32s3
- Screen Resolution: 320 x 240
- Graphics Library: LVGL 9.1.0
- Basic Environment: Complete the ESP-IDF installation, target chip, serial port, build, and flash verification in Lesson 1 first
3. Course Code¶
Main ESP-IDF Code Link: https://github.com/Elecrow-RD/CrowPanel-Advance-2.8-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-320x240/tree/master/example/V1.1_and_V1.2/ESP_IDF
The 2.8inch ESP-IDF uses the V1.2 version. The 2.4 / 2.8-inch lesson code is shared.
4. Course Catalog¶
| Lesson | Lesson Name | Main Content |
| 01 | Install Software Environment | Install the ESP-IDF environment, configure the target chip, and complete serial port verification |
| 02 | Network Audio Playback | Implement network audio playback using ESP-IDF |
| 03 | LVGL Light Control | Initialize LCD, Touch, and LVGL 9.1.0, and control GPIO18 through interface buttons |
| 04 | DHT20 Temperature and Humidity Display | Read DHT20 temperature and humidity data and display it on the LVGL interface |
| 05 | SD Card Image Display | Read image files from the SD card and display them on the screen |
5. Lesson Links¶
Lesson 01 | ESP-IDF Environment Installation and Serial Port Verification¶
Lesson Link: https://www.elecrow.com/wiki/IDF_01_Install_Software_Environment_V13.html
Lesson 02 | Network Audio Playback¶
Lesson Link: https://www.elecrow.com/wiki/2.4_2.8_ESP-IDF-02-Network_Audio_Playback.html
Lesson 03 | LVGL Light Control¶
Lesson Link: https://www.elecrow.com/wiki/2.4_2.8_ESP-IDF-03-LVGL_Light_Control.html
Lesson 04 | DHT20 Temperature and Humidity Display¶
Lesson Link: https://www.elecrow.com/wiki/2.4_2.8_ESP-IDF-04-DHT20_Temperature_and_Humidity_Display.html
Lesson 05 | SD Card Image Display¶
Lesson Link: https://www.elecrow.com/wiki/2.4_2.8_ESP-IDF-05-SD_Card_Image_Display.html
6. Recommended Learning Sequence¶
Study in order from Lesson 01 to Lesson 05:
- Development Basics: In Lesson 01, first complete ESP-IDF v5.5.4 environment installation, target chip
esp32s3configuration, serial port connection, build, and flash verification. - Audio Functionality: In Lesson 02, learn the network audio playback workflow and understand the audio playback tasks and peripheral initialization in an ESP-IDF project.
- Display and Touch: In Lesson 03, learn how to use LCD, Touch, LVGL 9.1.0, and GPIO control together.
- Sensor Display: In Lesson 04, learn how to read the DHT20 temperature and humidity sensor and update the data to the LVGL interface.
- Storage and Image Display: In Lesson 05, learn SD card file reading and image display to build a foundation for later graphical interface projects.
