ESP32 2.01 Watch Arduino 15 Lesson Course Guide
CrowPanel 2.01-inch HMI ESP32 Watch Display
15-Lesson Arduino IDE Course Guide
240 × 296 IPS Touchscreen · ESP32-S3 · Arduino IDE
Product: CrowPanel 2.01inch-HMI ESP32 Watch Display 240×296 IPS Touch Screen
Lessons: 15
Development Platform: Arduino IDE + ESP32-S3
Learning Path: Environment Setup → Hardware Interaction → Wireless Communication → Sensors and Audio → Power Management
1. Course Overview
This course series is designed for the CrowPanel 2.01-inch HMI ESP32 Watch Display. It guides learners through the onboard hardware and common ESP32-S3 features in the following order: development environment → basic input → graphics and touch → communication → sensors → audio → power management.
The series begins with Arduino IDE configuration and then covers the BOOT button, IPS display, touch control, LVGL graphics, rotary encoder, real-time clock, Wi-Fi, BLE, accelerometer, vibration motor, battery monitoring, speaker, microphone, and low-power sleep. After completing all lessons, learners will have the foundation needed to independently develop watch interfaces, connected features, interactive controls, and low-power applications.
2. Before You Begin
  • Hardware: CrowPanel 2.01-inch HMI ESP32 Watch Display
  • USB Cable: A USB cable capable of data transfer
  • Development Software: Arduino IDE 2.3.6 (recommended if other versions fail to compile)
  • Board Package: Espressif Systems ESP32 3.3.3
  • Test Device: A phone or computer supporting 2.4 GHz Wi-Fi and BLE
  • Basic Configuration: Board, Flash, PSRAM, and partition settings completed in Lesson 01
3. Course Catalog
Lesson Title Main Topic
01 Arduino IDE Setup and Serial Verification Configure the ESP32-S3 environment and verify uploading and serial output
02 BOOT Button Event Detection Detect press, single-click, double-click, and long-press events
03 Display, Touch, and LVGL Drive the GC9309 display, AXS5106L touch controller, and LVGL 9.1
04 Rotary Encoder and Push Button Detect clockwise and counterclockwise rotation and button events
05 PCF8563 RTC Basics Read the date, time, weekday, timestamp, and low-voltage flag
06 Wi-Fi Scanning and Connection Scan wireless networks and connect in station mode
07 Wi-Fi and RTC Time Synchronization Retrieve NTP time and write it to the PCF8563 RTC
08 BLE Communication Create a BLE service and characteristic for reading, writing, and notifications
09 Accelerometer and Motion Detection Read SC7A20HTR three-axis data and detect significant motion
10 Vibration Motor Control Control vibration patterns using GPIO and non-blocking timing
11 Battery Voltage and Charging Status Measure battery voltage with the ADC and read charging status
12 I2S Speaker Playback Generate and play a 440 Hz sine-wave test tone
13 PDM Microphone Input Capture audio and calculate peak and RMS levels
14 Audio Recording and Playback Process a recording in OPI PSRAM and play it through the speaker
15 Power Management and Light Sleep Power down peripherals, enter light sleep, and configure wake-up sources
Lesson 01|Set Up the Arduino IDE and Verify Serial Output
Lesson Link: View Lesson 01
Lesson 02|Read the BOOT Button and Print Events
Lesson Link: View Lesson 02
Lesson 03|GC9309 Display, AXS5106L Touch, and LVGL 9.1
Lesson Link: View Lesson 03
Lesson 04|Rotary Encoder and Push Button
Lesson Link: View Lesson 04
Lesson 05|Read the PCF8563 Real-Time Clock
Lesson Link: View Lesson 05
Lesson 06|Scan for Wi-Fi and Connect in Station Mode
Lesson Link: View Lesson 06
Lesson 07|Synchronize the PCF8563 RTC over NTP
Lesson Link: View Lesson 07
Lesson 08|BLE Services and Characteristic Communication
Lesson Link: View Lesson 08
Lesson 09|SC7A20HTR Accelerometer and Motion Detection
Lesson Link: View Lesson 09
Lesson 10|Control the Vibration Motor
Lesson Link: View Lesson 10
Lesson 11|Monitor Battery Voltage and Charging Status
Lesson Link: View Lesson 11
Lesson 12|Play an I2S Speaker Test Tone
Lesson Link: View Lesson 12
Lesson 13|Capture PDM Microphone Input and Measure Volume
Lesson Link: View Lesson 13
Lesson 14|Record Audio and Play It Back
Lesson Link: View Lesson 14
Lesson 15|Power Management and Light-Sleep Wake-Up
Lesson Link: View Lesson 15
Follow Lessons 01 through 15 in sequence:
  1. Development Foundation: Lesson 01 establishes the environment required by every later lesson.
  2. Hardware Interaction: Lessons 02–05 cover buttons, display, touch, rotary input, and the RTC.
  3. Wireless Communication: Lessons 06–08 cover Wi-Fi, NTP time synchronization, and BLE.
  4. Sensing and Feedback: Lessons 09–11 cover motion detection, vibration feedback, and battery monitoring.
  5. Audio Features: Lessons 12–14 cover speaker output, microphone input, and audio loopback.
  6. Low-Power Development: Lesson 15 provides an advanced introduction to power management and wake-up sources.
**Start with basic drivers and build a connected, interactive, and sensor-aware smartwatch application step by step.**
